366 engines
Discussion in 'Tow & Trailer' started by odee1, Mar 5, 2004.
  1. odee1
    odee1 Registered Member
    Feb 27, 2004
    50
    any of you guys use the chevy 366 big block engine in your tow rigs? I have gotten one for cheap and was wondering about it. Fuel mileage/power good-bad?
  2. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    366 = boat anchor.
    CR
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    366 = boat anchor.
    /forums/images/graemlins/histerical.gif
  4. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    My neighbor uses one in his tractor. He says it tugs better than the Olds 455's he has in his other ones.
  5. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    366 = boat anchor.
    Not exactly. It will be if you try to over rev it. But it does have great low end torque.
  6. got_mud
    got_mud 1/2 ton status
    May 9, 2003
    316
    Wichita, KS
    366 = boat anchor.
    yup. had one in or c60. grunt like a diesel. hope you got more than 4 gears to work through.
  7. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    The 366 has some useable part's if you can find a passenger/pickup bigblock block.
    Due to the .400 taller deck height found in these block's,[to accommodate 4 ring piston's] the block is pretty useless [unless you want to build a stroker]
    If you can find a passenger/pickup block, [shortdeck] you can use the crank, rod's, head's, pan, timing cover, etc.,a passenger distributor will be needed also, since the "truck" dist is .400 taller too. and build a "normal" bigblock.
    366's share the same stroke crank as a 396, or 427. Truck rod's are good and healthy on the big end, compared to passenger rod's.
    Pick up a book entitled, "How to build max performance chevy rat motor's" by Ed Staffel. Best damn book I've found for building a healthy Rat.
    Include's casting number's of block's, head's, rod's, etc. plus how to calculate compression ratio's, porting on and on... A must have when building up a Rat. /forums/images/graemlins/shocked.gif
  8. 75-K5
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Don, I haven't seen you post since long time. /forums/images/graemlins/thumb.gif
  9. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    I take the winter month's off, to play with snowmobile's, and spend time at snowest.com forum's.
    It's march, and just like the Gopher/Rat, whatever it is, see's it's shadow in february, I have returned.
    Or could it be a "sure sign of spring" /forums/images/graemlins/blush.gif
    Thank's for asking! /forums/images/graemlins/grin.gif
  10. odee1
    Feb 27, 2004
    50
    I've started to take the engine down to see what it looks like. I've toyed with the idea of putting the crank into one of the 454 blocks I've got to make a 427. Are the distribors different? I compared the hei that came out of the engine with a standard one looked to be the same. The intake was sunk at the distribor mounting pad.
  11. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    The "366" has a taller deck height, which in turn, make's the distributor out of the 366 non useable. [.400 taller]
    Dig up an HEI out of a smallblock, it will fit and work fine. /forums/images/graemlins/grin.gif
