366 truck engine ???
Discussion in 'The Garage' started by Donovan, May 11, 2002.
  1. Donovan
    Donovan 1/2 ton status
    524
    Arvada, CO
    Does anyone now if the heads off a 366 is the same as a 427? I really would like to know if the valves are the same size or are they smaller on the 366 engine? Does anyone know because I can't find anything on them. Thanks
  2. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    The 366 was a low RPM torque motor. I have never seen one that I know of but I will have to guess the valves and runners would be rather small.
    The 366 came up a few weeks ago, try doing a search.
    Are you looking for BBC heads and having trouble? Finding good Sq port heads may be hard but oval port heads are everywhere. Try to avoid late heads, they have smallish ports. I dont recall what yr the "peanut port heads" started, but I am thinking it was around 89 or so. Good port velocity for lower RPM Id guess but most people building a 427 are building an animal.
  3. Donovan
    524
    Arvada, CO
    I did a search and I found someone that might beable to help out. I want to change the heads on my 454 and I would be installing a new cam also. I plan to make this build up for max torque and to get good port velocity. I want the smallest head that I can get. So I was thinking that the 366 truck engine might have smaller valve in it. Max rpm I plan to run is 4500rpm so that the peanut head will be fine but if the 366 are smaller valves then that is what I want.
  4. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    What heads are you running now?I have a early '70s 454 with oval port heads.I just swapped cams with a 272/284 grind.This will pull hard from the get go.It has a 465 behind it and 3rd gear will throw you back in the seats.Try swapping cams first bet you will see a huge difference in power.
  5. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    If your lookin for max torque at low RPM pull out the 454 drop in the 366 and ship me the 454. /forums/images/icons/smile.gif
    OK OK you drive a hard bargain....Ill pay the shipping. /forums/images/icons/tongue.gif
  6. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Donovan,
    I think your thinking too much...
    I'm not sure if the 366s have smaller ports, but I would not be suprized to find it so. (The H/D 350s are "suposed" to have H/D flow-restricive ports and valves).
    Even if he 366s do have smaller ports, why would you want to restrict the engine so much? To gain a slight amount of low RPM power (at WOT)?
    For us, where we control idle/cruise speed with throttle input, the throttle-blades is the restriction, not the ports and valves.
    To put it another way, If you want more power to crawl over an obstical, you simply applie more pedal.
    Granted, higher low RPM port speeds will increase low-end torque - but thats only during WOT.
  7. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Just put a pontiac 455 in it /forums/images/icons/wink.gif
    Dan
  8. Donovan
    524
    Arvada, CO
    This is going into my Crewcab duelly 4x4. I need more low end in it. I would think with 4.56 that would be great but it is not. BTW I have a Caddy 500 going into my Jimmy this summer. Maybe I should just slide one of those into my Duelly. I will find out the answer hopefully tomorrow.
  9. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    If you want low end grunt in your dually, drop a 3208 Cat in there.
  10. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    My boss has an F-350 with a 460 and an auto and 5.40 gears and a Gear Vender overdrive unit tows his goose neck with a small dozer on it no problem. Basicly you can split any gear or run double overdrive.
  11. Donovan
    524
    Arvada, CO
    I have thought about putting cummins in there but I don't have the money to do that. So the next opinion is to do something with the 454.
    I did find out the valve size on 366 engine and they made two intake sizes and they are 1.94 and 1.84 and the exhaust is 1.66. I don't know anything about the CC's in the heads.
  12. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    I think a pontiac 455 would have more than enough low end power for you. The pontiacs have alot more low end than a BBC. The caddy would work too.
    Dan
  13. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    A friend of mine in Colorado Springs has an Olds 455 for sale for $400. It was in a Jeep Wagoneer that he bought. It was running strong before he decided to part out the Jeep. It's complete from carb to exhaust manifolds. /forums/images/icons/cool.gif
  14. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Oh yeah, he's got the Turbo 400 that was bolted to it for another $300. /forums/images/icons/wink.gif It was adapted to the Jeep transfer case, so I don't know if it has the stock output shaft or something from Advance Adapters.
