36's no lift, how much hacking?
Discussion in 'The Garage' started by Paxx, Mar 14, 2004.
  1. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    36\'s no lift, how much hacking?
    I think my next phase is going to use 4.10 d44-14bff axles, 36"x13.5" Iroks, no lift, massive trimming. Does anyone have any pics of this or a similar set-up? Even pics of 35" tires with no lift would help give me an idea.
    I'm hoping that it will be close to the same amount as a 4" suspension w/39.5's as this will be my final set-up. I would like to do all the hacking right now so that if I buy wrap around bumpers and rock sliders they will all fit the same this phase as they would on the 39.5" phase. /forums/images/graemlins/waytogo.gif
    Let's see some pics or hear some stories /forums/images/graemlins/deal.gif /forums/images/graemlins/ears.gif
  2. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Re: 36\'s no lift, how much hacking?
    I just happen to have a pic of a test fitting of 35x12.5x15 on my K5 with NO LIFT. It doesnt turn at all without trimming for sure
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    1 ton axles and no lift. /forums/images/graemlins/rotfl.gif
  4. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    here are some 40's with 4 inches of lift to give you some reference maybe.
    it wasnt flexed completely, i'm pretty sure i couldnt flex fully with out rubbing.
    [​IMG] [​IMG]
    [​IMG] [​IMG]
  5. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    Do you guys figure that there would be the same amount of trimming for the 4" and 40's as 36's and no lift?
  6. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Actually that was taken before the 1 ton axles . Those are good ole 6 lug wheels /forums/images/graemlins/waytogo.gif
  7. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    Hey Branndon did you have to modify your inners when you made those cuts or is that as large as you can cut without modifying them?
  8. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i had to modify my wheel wells. i they pretty much bolted back in except for the rear part where the angle of the cut is greater, a couple snips on the wheel well for flexability and a 4 pound sledge hammer, and we hammered the inner back flush with the truck. /forums/images/graemlins/thumb.gif
  9. tRustyK5
    Jul 23, 2000
    36,168
    1,366
    E-town baby!
    No, 36's and no lift would require more trimming. 40's have 2" more radius than 36's. The rear won't be much of an issue...my 36's would stuff completely into the wheelwell. However, the 36's will hit the inner part of the wheelwell in the rear for sure with no lift.
    Up front you're gonna hit badly even with the mongo trimming I think. Trimmed a lot, 4" lift and all crossed up with stiff Rancho front springs I was close to the firewall if the wheels were turned. With no lift and much flexier stock springs it would have hit for sure.
    I'd say lift it 4" and run the 36's for now and 40's later. For the 40's and that lift you'll need to shove the front diff forward at least an inch and get a little creative with the sheet metal.
    Rene
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I should have looked closer I suppose. Driving a K5 with 1 tons and no lift would look kinda funny though, like the guy around here with a dually axle in his C1500 that is still 5 lug up front and only has one tire on each side in the back (the inside dually tire). /forums/images/graemlins/rotfl.gif
  11. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Man, you need to tape off a half inch border around your fender openings and flat black that sucker
  12. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    Can you move the front axle forward an inch to an inch and a half without affecting your steering?
