36's on 10 bolts?
Discussion in 'The Garage' started by natehate, Nov 25, 2005.
  1. natehate
    natehate Registered Member
    Sep 15, 2005
    56
    onterrible canada
    anyone doing it?
    hows it going for you?
    i have the 30 spline version if that makes any difference
  2. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    how wide? i ran 35x12.50's with heavy foot in mud and didnt have a problem
  3. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
  4. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I run 35s on 10 bolts with no problems yet. My son runs 37s on his locked 28 spline front and he broke his first ujoint last weekend. Just keep a set of spare axles with you, or at home. When he broke his u joint it ruined the axle , but he kept wheeling for another 4 hours in 3wd and drove it home.
  5. sledheadak
    sledheadak 1/2 ton status GMOTM Winner
    Apr 29, 2005
    1,283
    anchorage,alaska
    i ran 36x12.5" super swamper tsl all summer ,even with the rear welded and had no problems,ran a combo of rocks and mud.
  6. sope
    sope 1/2 ton status
    Jul 8, 2005
    967
    British Columbia
    I figure it's OK if your not locked.
  7. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Not enough info to help you out.
    1. Is it your DD?
    3. What drivetrain combo? 350/700r4-208? Gears? 3.08's??
    4. What is your driving style? Throttle jockey or finesse driving?
    5. What kind of terrain? Mall crawler? Mud? Rocks? A little of everything?
    6. What do you want to do with it?
    Answer those and you'll get better educated responses.
    Personally, I ran 38" TSL's on 1/2 ton D44/12B combo for years and never broke anything. I am not a throttle jockey unless I'm in mud or some other terrain that gives.
  8. blazerpro79
    blazerpro79 1/2 ton status
    Jan 4, 2005
    528
    Simi Valley, CA
    i run 35s on a 10/12 combo and im a lead foot! i have 4.56s and never have had any problems. ive been running this setup for almost 3 years, and the PO did it for about 10 years.
  9. brotha b
    brotha b Registered Member
    Nov 4, 2005
    31
    vernal, Ut
    10 bolt
    you will probably be allright in softer conditions but if you hit rocks and like most of us get a little heavy on the foot its pretty much inevitable that 10 bolt is gonna break most likely a shaft and then your wheel can fall off
    id say go bigger its worth knowing your much safer
  10. stayaway
    stayaway Registered Member
    Aug 1, 2005
    59
    georgia
    I run 36s on 10/12 bolt welded and so far so good
  11. natehate
    Sep 15, 2005
    56
    onterrible canada
    350 700r np241 with 308 gears
    a little bit of everything wheeling wise except deep mud
    daily driven for now
    its to rusted out to wanna throw 1ton axles at it
    and i have a bit of a heavy foot but not to to bad
  12. 74757685k5
    74757685k5 1/2 ton status
    Nov 13, 2004
    258
    montana
    Three O Eights And Thirty Sixs Are You Kidding? Good By Over Drive!
    Sorry I Cant Use Numbers All I Get Is This !@#$%^&*()
  13. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    You will be fine. You probably won't break a shaft every trip, but plan on it. Carry spares and wheel your heart out!!
    I know lots of guys with locked front and rears with 36" Iroks who wheel rocks all the time. The do break, but if your proficient enough you could change a shaft in about 30 minutes :wink1:
    If you are open up front it will lessen your chances of breakage.
  14. natehate
    Sep 15, 2005
    56
    onterrible canada
    yeah i wanted to change those with the tires
  15. sope
    sope 1/2 ton status
    Jul 8, 2005
    967
    British Columbia
    I Have broke two front U joints, both times taking out a shaft and one rear axle running 10 bolts and 35's. The time I broke the rear axle was the day after wheelin and it broke when my locker enguaged driving down a prety buisy street. I was lucky I was able to slow down and pull off just as my axle came completely out. It did come out and my wheel and about a two foot section of axle rolled and hit my front fender. Looking back on this, it was lucky the axle didn't come out at a higher speed. Someone could have been really hurt or killed. I think a lot of us, including me don't always think about breakage while driving down the highway.
  16. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Good point :doah:
  17. brotha b
    Nov 4, 2005
    31
    vernal, Ut
    only in the mud or the soft hit rocks like a crawler and your broke
