37"-38" and 4:56?
Discussion in 'The Garage' started by stockk5, Sep 20, 2005.
  1. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    Hey. i tried to search and search for an answer on this but nothing ever comes up. I was wondering how would 37-38" tires and 4:56 gears feel and run on a k5. Would it be a good idea to go bigger gears? or would they feel alright. This is my DD and im into more trails w/ some rocks, not crazy rock crawling and mud.. I am running a 305, 700r, 208.. soon to be 350tbi
  2. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    I am running 39.5" with 4.56's 454/465/205 DD works for me!!! :D
  3. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    I ran 4.56 gears with 35" tires in a 86 Blazer for a while. It was a 35/700R4/NP208 Dog. The 4.56's helped the thing outta the hole and was only a couple hundred RPM more than the stock 3.73's. I would think with the less torque of a 305 or mostly stock 350 go with 4.88's with a 38" tire. I just checked the tire hieght, gear ratio, speed calculator at Randy's Ring And Pinion websight and 4.56 gears with 38" tires put you a tad under stock 3.73's and 31" tires. Me... I would go 4.88, only about 100 RPM more than stock in OD.
  4. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    I've got a TBI350/TH400/NP208 w/ 4.56s and 13/38/16 TSLs and it ran just fine in the trails and okay for the occasional road use.
  5. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,486
    1,191
    So Cal.
    i have 4:88's and 38's going on my rig, 383, th400 trans. just will run up in the rpm's a bit on the freeway, no big deal, unless your worried with the fuel cost these days.
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    You need more gear. You need at least 4.88's but I would recommend 5.13's if you are planning using overdrive at any time. I run TPI 350, 700R4, 208, 4.56's, and 37" MTR's (really only 35") and I need more gear.
    I wanted more gear when I was running 35's and 4.56's. The only reason I haven't swapped in 5.13's is because I am swapping to a TH400 tranny next and I won't have OD.
    Harley
  7. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    The 700 has overdrive so go at least 4.88. I am changing mine to 4.56 with 35"
  8. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    4.56's would be liveable but you won't be using OD very much. With that said if your axles already have 4.56's installed I would try them first and see what you think. If you are actually swapping in new 4.56 gears than I would say don't waste your money and go straight to 5.13's.
  9. paulmoon
    paulmoon 1/2 ton status
    Feb 11, 2004
    211
    Reno, NV
    I'm running TPI350/Th350/NP205/4:88's with MTR 37's on my DD. Not a lot of freeway driving but it's OK wheb I do. RPM's aren't too bad even without OD. With 38's I'd go a least 4:88 if not 5:13's...IMHO
  10. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Im running 5.13's with my 35's. At about 65mph I am turning around 2600RPM which isnt bad for my motors range.
    I went from 4.88's to the 5.13's and I cant really tell much of a difference on the highway other then the 200RPM bump at high way speeds. But when in low crawling I can tell a BIG difference.
  11. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    I know deeper is better, but 4.56's and 37's-38's would not be terrible. I mean it would be ton's better than running the stock 3.08's that I have now with 31's. For the love of God, this ratio is horrible, it's not even on the Chart and It is still bearable. I'm gonna be running 4.56's with 40's for a while 'till I can regear, and don't expect it to be that bad based off of my present setup. I'll just not use OD if it comes to that.
  12. sledheadak
    sledheadak 1/2 ton status GMOTM Winner
    Apr 29, 2005
    1,283
    anchorage,alaska
    try 2.73s and 36s. :eek1: :eek1: really sucks but i get 15 mpg or on the trail lol
  13. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
    What tranny do you have? Sounds like a bomb in the making!
  14. zero cool
    zero cool 1/2 ton status
    Sep 19, 2005
    150
    Austin, TX
    I wrote a little Java craplet to do side-by-side comparisons of gear ratio changes...
    http://www.dfw-tx4wd.org/gears.html
    Oh, and it doesn't have the NP241 in it. Just use the NP242, it has the same low range. That's on my (rather long) list of things to add.
  15. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    it depends on which tranny you got. 700, go with 5.13s. for 350/400 go with 4.56
  16. sledheadak
    Apr 29, 2005
    1,283
    anchorage,alaska
    i have a th350 in it now.i am replacing the axles with d60/14b with 4.1-s for now it will go to 5.13s next year.
  17. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    That is in the favorites list now
  18. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    I am running 38.5's with 456's and I do good all around, But I have a 465 trans in mine so I have the granny low for off road. I would have to agree with most of the other post. If you are buying gears regaurdless get at least 488 and 513's would be perfect. Otherwise you will suffer off road at times and will loose a lot of power in OD.
  19. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Go as deep as you can go with the 700R4.
    I chose 4.56 for my OD trans, but I plan to swap to a T400 in the future. I will probably want more gear in the future too....
