37 goodyear mtr
Discussion in 'The Garage' started by 74beater, Aug 23, 2003.
  1. 74beater
    74beater 1/2 ton status
    Sep 20, 2002
    242
    ELGIN ,TX
    is anyone running this tire..that can give me some feedback...
    all hail the almighty sawzall
    35 d44 12
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    don't have them but they are MT/Rs and I have heard nothing but good about MT/Rs. I want to run them very badly but gearing will cost too much.
  3. 74beater
    Sep 20, 2002
    242
    ELGIN ,TX
    what gear should i use...
  4. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    4.56 would be a good choice, IMO. Depending on your engine, 4.11's will work also.
  5. ducttape114
    ducttape114 1/2 ton status
    Aug 1, 2002
    990
    Orcutt Ca
    i run them and i love em. they are farily inexpensive as far as rubber goes. they grip real well, are pretty quite, and last a long time. the only thing i dont like about them is that they get a lot of side wall flex at low pressure (2-4 psi) but so will any other 37 on a 15" rim. tirerack.com has them for a pretty good price i belive. and thats all i have to say about that /forums/images/graemlins/grin.gif
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    FOr me I want 4.88s if I get 37s for the simple fact that I like a vehicle that moves when I want and 4.10s with 37s won't get out of anybodies way quickly.
  7. 74beater
    Sep 20, 2002
    242
    ELGIN ,TX
    160 bucks is cheap....4.88 it will be thanks guys
  8. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    i have heard nothing but good for MT/Rs.
  9. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    They are a kick arse tire /forums/images/graemlins/thumb.gif. Unfortunatly you cannot get them now or in the distant future. I know the 37's in the 15 and 17" flavor are nonexistant, not sure of the 35". Goodyear halted production of them for the war, and from what I understand they are now made of unobtainium /forums/images/graemlins/angryfire.gif
    Here's some more info...............................
    Read on!
  10. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    IMO...
    MTRs in general a good tire with good all around traction and handling characteristics. Their main shortcoming, and it's enough that I wouldn't run one even if they made one big enough, is that like most all radials, the sidewalls are weak and that AZ terain eats them alive. You have to watch your sidewalls like your drive shaft. Bias TSLs laugh at the stuff, but the traction on rock is not as good. <sigh>
  11. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    I just emailed Goodyear to hopefully get a straight answer. I'm really curious about this because my 37x12.5x15's are supposed to be here on Wednesday /forums/images/graemlins/confused.gif
  12. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    IMO...
    You say the sidewalls are weak? Not doubting your opinion but have you seen or felt the sidewalls on these?..they're huge compared to say a BFG Mud TA.
    A majority of the desert racers use them because of their tougher sidewalls ..or so I've heard. Actually was watching it yesterday on TV and they were specifically talking about the MTR's saying how great they were. Could have been a plug for goodyear but if the desert racers are still using them then they have to still be available too...I hope
  13. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Wanna bet. /forums/images/graemlins/wink.gifAnyhow I'm running 37x12.5x17 MTR's on Donna's K5 with 4:10's. Yes it is not extremely quick off the line but pushing 6000 pounds with a tired 350 it's not all that bad. I'm not running overdrive trans so I wanted the highway rpm's to be low. As far as the MTR's go not much more to say then /forums/images/graemlins/thumb.gif.
  14. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    As far as sidewall strength, I will ? that. I smacked them pretty good on the sidewalls and twisted the tires pretty good with no problems at all. I personally have never seen or heard of a sidewall issue on the MTR's.
  15. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Rearead B/D's reply.
    Looks like he was comparring Bias -vs- radial sidewall strength, in genneral. Not just the MTRs.
    Bias ply will have a stronger sidewall than ANY radial.
  16. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    [/ QUOTE ] Finally someone running 17''s! /forums/images/graemlins/cool.gif what wheel are you using and with what backspacing? I can't find a damned thing with less than 4 1/2'' backspacing /forums/images/graemlins/mad.gif and I was shooting for +/- 3 1/2'' and I highly doubt that 4 1/2'' will clear my histeer arms /forums/images/graemlins/tongue.gif
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    What you've got is TOO LOW of RPM. I had 4.10s and 35s when I had a 700R4 and that thing was a total pooch. I can't imagine, it has to be HORRIBLE in OD with 37s unless you live in Nebraska or something where there are no hills at all.
    4.56 would be ideal with 35s for a 700 IMO. 4.88 for 37 or 38 and at last 5.13 for larger tires. Without OD, 4.56 for 37 would probably be ok. I run 4.10 and 38 and I think I have enough gear, but I don't have OD.
  18. Donna
    Donna 1/2 ton status
    Feb 20, 2001
    2,377
    Gettysburg,Pa
    Hmmmmm, to low of an rpm? DUH what part of I'm NOT running an overdrive did you not understand.It has a th400 in it and it runs fine through the mountain roads here which is almost all roads since we basically live at the bottom of one. /forums/images/graemlins/rolleyes.gif It will run 75 up the interstate all day long with no problems.
  19. Donna
    Feb 20, 2001
    2,377
    Gettysburg,Pa
    I ordered the wheels from Rockstomper. They are not beadlock but they are steel. They are 17x8 with 3 3/4" backspacing but Scott will build them in different backspacings.
