37 MTR’s and a 4” lift
Discussion in 'The Garage' started by bangedup, Jan 30, 2005.
  1. bangedup
    bangedup Registered Member
    May 17, 2003
    21
    Alberta
    37 MTR’s and a 4” lift. Anyone run this combo? I’m thinking of going this route and would like to hear any negatives as apposed to 35”s. I plan on some fender trimming in the front and don’t anticipate any needed in the rear (yes/No?) Any rubbing in the rear inner fender? Ect...
    Plan on 10.0 x 15s wheels on ¾ ton running gear little or no rocks so I’m not too concerned with the axel size mostly deep mud and light trail running. The reason for the MTR’s is it is still a dual propose vehicle with the need for good winter driving characteristics.:grin:
  2. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Harrison (87BrnRsd) is running this combo.
  3. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    I ran 37" Goodyear MT (hummer tires) on my blazer with 4" of lift. I needed to trim the front but not the rear.
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    It will fit with some moderate to heavy trimming. A buddy of mine runs that combo. Matt (az-k5).
    Harley
  5. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    i'm gonna shackle flip the back, 4" E-Z rides up front, 0 rates all around and 1" body for 6" total, and i'm thinking 37" MTR's.... hopefully i wont have hack it too bad..
  6. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    MT/Rs + mud = bad from what i hear.
  7. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    37's on a 4" lift make for a very stable vehicle. MTR's in mud make for one disgrunteled (sp) driver. They are absolutely worthless in mud. Kick ass in sand, dirt, rock, pavement, but put water in the mix and they fall way behind. They are an awsome dry tire but if you won't be in the rocks then they probably are not for you.
  8. eclipse
    eclipse 1/2 ton status
    Jan 1, 2005
    1,245
    Sparks, NV
    "MT/Rs + mud = bad from what i hear."
    I've heard the same and with there tread design, I can see them getting filled up with mud easy and not cleaning out.
  9. bangedup
    May 17, 2003
    21
    Alberta
    Thanks for the replies. Ya I know but running swampers at –35c on ice is not an option. I have run BFG MT’s and am not impressed with them, I would even say that they suck and on ice they are just plain unsafe.
    I figure new MTR’s and having them sipped will help the winter wheeling and they can’t be any worse than BFG’s in the mud.
  10. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    yeah, i'm concerned about that.. street and mud, no rocks... hunting sizes becomes an issue for me too.. i want a 37 or 38, but i'd like 13.50, not 12.50, like the MTR..
    SSR's, Iroks, MTRs are all in the running at this point. SSR's in 37 x 12.5. Iroks in 36x13.50 or 37x 12.50 or MTR's in 37x12.50..
    actually i think i might be inclined to run the 36x13.50 Iroc radial as of right now. i like that size... i assume mileage is somewhat worse with the Iroc over the MTR. performance i would bet is better. might be a tad noisier i would think... prolly work well with the 4.56's i plan on...
    i'd like it in 37x13.50 or even 38 if they made that.. a 37x12.50 just sounds skinny to me...
    but i can always go bigger next time.. thanks for any suggestions... :ears:
  11. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    as far as rear clearence goes i havent trimmed or touched(with tire) with 38's and 4" of lift.
    by the way what ever happened to the post about the 37" MTRs that someone had a recipt for at wal-mart for 160$ a piece? iv looked for a copy on pirate/austink5/and texas4x4. i could really use some in the near future
  12. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    I just priced them last week at Walmart and they were $200.64 each plus mounting @ $9.76 each.
  13. afflictedpast
    afflictedpast Newbie
    Apr 25, 2004
    4
    Discovery Bay,CA
  14. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Not what I hear but what I have seen, they are absolutely WORTHLESS in mud even with wheel spin.....on a slightly sloped trail I watched 3 - 4 other trucks make the hill before the jeep with MTR's made it. The other trucks were running, swampers, BFG muds, mud brutes, some other retread mud grip, the guy with MTR's was getting pissed, all of the rigs were about equally equipped.
  15. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    My MTR's haven't let me down in the mud, but then again my driving style may have something to do with it;)
    John
  16. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    I am running 37" MT/R's on a 4" BDS lift. I had to do quite a bit of trimming on the front and beat the inner wheel well in as well. With quite a bit of flex I they don't rub and I think it is a very good combo for a vehicle that sees a lot of rock crawling because of the low center of gravity.
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I've seen MT/Rs do just as well as BFGs in the mud, and they have stronger sidewalls to boot.
    That said, I would get a set of all season or all terrains for the road, and get a set of bias swampers, maybe IROKs for the trail.
    If you have to drive in ice, no decent off road tire is going to offer decent traction, and most will wear fast on the road.
    Having two sets of tires is the answer.
  18. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    Beat me to it Tim. If you are driving on ice, i mean ice, not 3" of snow, everything is gonna suck. BFG's, MTR's, TSL's, it doesnt matter unless you sipe them, then they wont suck as much. If you are that worried about driving on ice, pick up a set of used AT's cheap out of your paper.
    As for snow driving, even my TSL's were doable. The only reason i have my AT's back on is because im driving a lot more now, and by summer i will have put easily another 12K miles on my truck.
  19. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    I'm going to run 37s with less than 4" of lift
    I plan on running 37" MTRs with less than 4" of lift. Now it may only be 1/2" less than 4".:wink1: I'm figuring that I will need to do some "fender massaging".:D
    FWIW: I saw a jeep today with 37" MTRs, so I measured the actual diameter. It was 35.5" and they appeared to be fully inflated. I also think that was on 10" wide wheels, but only guessing there.:dunno:
  20. bangedup
    May 17, 2003
    21
    Alberta
    I have a set of street skins now. I’m getting lazy these days and I really hate tripping over the extra set all the time .In an ideal world I would have a larger shop with more storage and someone to swap out tires every time that I wanted to go out and play.:D
    Ice is all we have this year –1 c and rain one day then down to –30c the next only to switch it back up to some more rain. Weird **** happening up here.
    You are probably right though, I will have to run a winter tire. :mad:
