373 rear end
Discussion in 'The Garage' started by adamforsythe, Feb 1, 2005.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    So how good is the 373 rear end for rock crawling, and mudding.
    Adam
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    All depends on what set-up you are running. If you have a doubler or low gears in your t-case, then you shouldn't be bad. Also it factors in whether you are running a stick or auto, etc.....
    I know when Shannon Campbell ran "pinky"(his tube frame Willys), he was supposedly running a junkyard 10 bolt and 12 bolt with 3.73's.. But he was running a 3.8:1 Atlas t-case an auto and 37's....
  3. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Hello,
    Well here is my set-up
    NEW 350 4 bolt (kinda built up from stock)
    New Th350 with a NP208 T-case
    31" tires
    1985 K5 Blazer
  4. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    There good if you have 31" tires. Right now I am running 35's with 3.73's and my truck has No balls. I have a crane cam and new heads in my 350 and with 3.73's they really hurt me. Right now I have an ARB in the front and changing gears is not an option unless I want to loose the ARB. Eventually I will change to 4.88's so I will have the option to go bigger with tire size.
    As of right now I rock crawl, I have a SM465 and a NP208. My low range is pretty deep and I have No problems in that since. When I do hill climbs in the sand is where I really notice it and on the street.
