373's and 35" tires
Discussion in 'The Garage' started by Z3PR, Nov 8, 2002.
  1. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    373\'s and 35\" tires
    I want 4:56's, but I know it'll be a while befor I can swap gears. So will 373 gears be okay with 35" tires on my 76 Blazer with a 400 small block and TH350/NP-203 ???? It's still fulltime and I think I'll keep the fulltime couse I like the way it handles.
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Re: 373\'s and 35\" tires
    <font color="green"> It will dog a bit, but it won't be undrivable by any means. It will sure make you want to get the 4.56s sooner though. /forums/images/graemlins/grin.gif I know Shewheeler has been running 3.73s with 35s for at least a few years now.</font color>
  3. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I had 3.73's and 35's for while. Ive got a stock 350/700 and it wasnt bad at all. I just went to 4.56's when I got my 36's. /forums/images/graemlins/smile.gif
  4. BulldogK5
    BulldogK5 1/2 ton status GMOTM Winner
    Sep 19, 2002
    4,158
    Brandon, MS
    I'm running that setup now. If you run any hills especially on the Interstate it will make you mad. Passing is a real PITA with those gears. Be sure and maintain your tranny, maybe put a cooler in it. I had to rebuild mine.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The 3.73's won't be totally undriveable with 35's. /forums/images/graemlins/wink.gif But I wouldn't go with 4.56's and 35's behind a non-overdrive tranny. I've got a Turbo 400, 4.10's and 35's and the engine is really singing on the highway. 4.56's would have you cruising in the slow lane or revving the snot out of your engine. /forums/images/graemlins/frown.gif
  6. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Im not certain, but I get plenty of pep out of my 373's and 35's. nothing totally neck snapping, but eough to beat hondas off the line. Perhaps its that low first gear of the 700R4?
  7. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Yep, with the 700R4's first gear, 3.73's are more like 4.56's would be behind a Turbo 350, so it will launch off the line pretty good. But once you get up to speed, the engine lugs on the highway in overdrive. /forums/images/graemlins/frown.gif
    I think first gear in a 350 is around 2.48:1 and in a 700R4 it's 3.06:1. So the overall gear ratio in 1st is:
    Turbo 350: 2.48*4.56=11.3088
    700R4: 3.06*3.73= 11.4138
  8. fulltopblazer
    fulltopblazer 1/2 ton status
    Aug 1, 2001
    484
    Altus,Oklahoma 73521
    I run 3.73's with 35's its not that bad.
  9. bobsurf
    bobsurf 1/2 ton status
    Jun 26, 2001
    410
    San Marcos, CA
    Not to necessarily hijack this thread, but my big debate is whether to go with 4:10 or 4:56 with my 35's (350/203). If I am driving highway, I don't plan on hauling a$$, so that might be my answer right there. If I find the 14 bolt with 4:56, I'll probably just go with that.
  10. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    If you can find a 14b with whatever gear size, i'd do that, and save the extra money from re-gearing to regear the front. I spent 1k to rebuild my 10b rear end with a eaton. Had my brain acutally been screweed in properly, I would have gotten a 14b. I cant see myself going bigger than 35's (thats what I said when i went from 31's to 33's). But if you upgrade to a 14b now, you can always go bigger.
    I've always been an engine lugger. Not to the point of bogging it, but I like to keep the rpms low. Even on my stang, I shift into 5th at like 2000 rpm. Well.. except when doing the fun stuff. /forums/images/graemlins/cool.gif
    My sitting on my ass at home has made my mind weak. But Here's what I would recommend- Do the gear calculation that was listed above, use that gear/tire size calculator, and figure out your final engine RPM at your desired cruise speed. That will give you base line calculations. Then you can fiddle with your optimum acceleration gears. (my guess is probably the 4.10's would be optimal, but you'll upgrade to 37's .. hehehee).
  11. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] Future plans include larger tires.
  12. bobsurf
    Jun 26, 2001
    410
    San Marcos, CA
    Getting the 14b is definitely going to happen and was never in question. I've already got the 8 lug D44, but it just needs to be regeared to match the junkyard 14b. Supposedly 4:56s are as common (if not more) than 4:10 in the Jyard.
  13. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Not to be an a**hole or anything, hey wait, I got called nice yesterday by the older hottie so I've got to make some space up......
    Anyway, if you were to peruse the 73-87 Forum a little bit, this same thread was going for a little bit about a week or so ago. /forums/images/graemlins/thumb.gif
  14. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    If future plans include larger tires than definitely go with 4.56's. I wouldn't go with 3.73's, I would at least run 4.11's with 35's. I ran 4.56's and 35's for awhile and it was fun. Now I need 5.13's with these 39.5's.
    P.S. TH350 = 2.52:1 1st gear LOL
  15. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    I run 4:56 gear sets now with 38.5TSL/SX's and I wished I had opted for the 5:13's instead!
    Bill
  16. Troopie's Tonka
    Troopie's Tonka 1/2 ton status
    Oct 3, 2002
    284
    Aiken, SC
    I just found out, after i took the diff cover off, that i had 2.73's... i bought the truck 3 months ago with 35's on it, the front 2 were worn bad on the inside, which means these tires had been on for a while...now i have 4.56's with 36" TLS's..
    question is...how much damage and where, if any, may this previous combination have caused?
  17. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    To my understanding,
    Large tires, plus highway gears equeals fawked up transmission.
  18. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
  19. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    35" with 4:56 would be bad juju...i have 4:56 with 37"s and i am still reving the piss out of my motor just tryin to keep with the flow of traffic...it sits at 3500 RPM on the freeway..i would like to see it more under 3000
