37's under a 4 in. lift?
Discussion in 'The Garage' started by kylo28, Apr 5, 2004.
  1. kylo28
    kylo28 Registered Member
    Mar 4, 2004
    80
    Modesto, CA
    37\'s under a 4 in. lift?
    How do you think 37's under my 4 in lift would perform? I want to keep my center of gravity low. How much fender hacking should i have to do? And wil it look good? I dont want oversized tires on a little lift. /forums/images/graemlins/hack.gif
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Re: 37\'s under a 4 in. lift?
    anything bigger than 33s or 35s is oversized tires on 4" of lift. I'm going to run 40s on 4" of lift. How will it look? I don't care too much. Can it look good, damn sure.
  3. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    petersons put 37's with 4" lift on their army truck project. they said it only needed a small amount of trimming. im not sure how much they consider is a small amount. i think there is an article on the truck in this months mag. i dont think it would look oversized. i would do it if i had one tons.
  4. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif
  5. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    heres an idea but this is before trimming /forums/images/graemlins/peace.gif
  6. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I run that set up and love it. There is a lot more than a little fender trim to fit them however.
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I think Peterson's has stiff springs since they have a diesel on top of them.
  8. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I hope I can I hope I can!
    I'm planning on running 37's and 4" of lift, rear axle will be moved back 3.5" and if I need to run a zerorate upfront I'll push the front axle forward an 1" also. I dont mind the trimming, I have plans for tubbing out the rear a little and flat inner fenders at the body line /forums/images/graemlins/whistling.gif
  9. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i have 40's on a 2.5in lift so i think you can get 37's under 4in lift with no problem /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  10. kylo28
    Mar 4, 2004
    80
    Modesto, CA
    Az-k5 Your truck (the white and blue one) only has 4 in lift? That truck is awesome! I want to get those goodyear mt/r also. But I still have 1/2 ton. I have rockcrusher gears and 30 spline upgrade. I think she should be ok. /forums/images/graemlins/histerical.gif
  11. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Here is mine with 37's on 5" I ran these with 4" but rubbed under full flex a bit so I added a zero rate and moved the axle an inch foward no more rubbing /forums/images/graemlins/peace.gif /forums/images/graemlins/hack.gif
