37x12.50x15 tires
Discussion in 'The Garage' started by cjjones, Apr 23, 2006.
  1. cjjones
    cjjones 1/2 ton status
    Feb 20, 2006
    111
    To the north
    I am looking to put on a set of 37" MTR's. Can someone help me, where to find a set of 10" rims, Is there a vehical that uses this size of rim?? Or am I going to have ot go to after market rims??
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    4 wheel parts has a line of powder coated steel wheels that are fairly cheap (~$35 a pop) and reasonably good looking.
  3. cjjones
    Feb 20, 2006
    111
    To the north
    Thanks, I was trying to get away from buying new rims, I would like to go to Dana 60's before I start to wheel too hard, so I would have to change rims again.
  4. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    I think you can run a 15x10 on a D60. I know you can run it on a 14ff. You can get some steel ones from summit for around $40 each.
    -Harrison
  5. 1977k5
    May 26, 2003
    9,996
    134
    He's saying he will have to change from 6 lug wheels to 8 lug wheels.
  6. 87BrnRsd
    Apr 21, 2003
    2,457
    Ahhhh.....forgot about that little factor:crazy: :doah:
    -Harrison
  7. cjjones
    Feb 20, 2006
    111
    To the north
    Thanks guys I am looking for new as we speak. Thanks for the help.
  8. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Just put them on your stock rims. I run mine on 8" wide rims and if you have the stock steel rims they should be 8" and the stock alloys will be 7" and you should be able to put them on those too.
  9. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    The stock steel white ones were 15x7, the stock steel ralleys were 15x8. My 33x12.50 crown bad on the 7" but 35x12.50 were great on the 8".
    15x10s with the 6 on 5.5" pattern are so common I'm sure you could find a used set cheep.
