38.5" Boggers, trim, no lift- SUCCESS! Pics added 10-12
Discussion in 'The Garage' started by monster man, Oct 11, 2005.
  1. monster man
    monster man 1/2 ton status
    Oct 20, 2003
    282
    Reno, NV
    got my Boggers today, mounted them on my K20, 38.5"-11-15's with 15x8 steel rims and 2.75" backspacing, a lot of trimming, and no lift. They fit well! :D As long as you're not flexing it out off road there is no rubbing at all. I took it in the bumpy field next door to our buidling and no rubbing, I wasn't rock crawling or anything though. I wish my camera batteries were not dead, you could see how much trimming is necessary. I will of course put a lift on to get some suspension travel and ground clearance, but if you're not inclined you could probably trim more than I did and never need a lift. Stay tuned
  2. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    :bow:
    I was thinking of getting a 3" lift, then 33" boggers.. lately I've been thinking about getting the 33's, using a sawzall, then maybe in the future getting a lift.
    post some pics, I would love to see that.
  3. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
  4. monster man
    Oct 20, 2003
    282
    Reno, NV
    I'm working hard to locate some batteries at my office- if not it will be tomorrow. But, I pretty much cut the front fender wellall the way to where it starts becoming support for the front end, right down past the turn signal, and to the back up to where the cab firewall starts showing. Then about 3" above the tires is cut, you could go more though easily. There are no inner fenderwells, I will fab some new larger ones if I plan on mud running. The back is cut about 1.5" all the way around, that was the easy one
  5. sparkyincali
    sparkyincali Registered Member
    Sep 30, 2005
    6
    Sf Bay Area
  6. monster man
    Oct 20, 2003
    282
    Reno, NV
    I know, I know, I shouldn't have teased you without pics
    I took it off road in several spots, and the tires did rub when I had the wheels turned and going over rocks, but really nothing bad. A bit of minor trimming and she'd be good. It was a pretty rocky trail getting up to the water tower, so I was happy, can't believe it had no lift :D
  7. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I say trim a little more and run no lift. Maybe just a 1" Body lift. Looks good as it sits.
  8. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    Sheesh... what am I doing wrong? I rub my 38s on this thing! :) I just think youre not trying hard enough! LOL
    Mike
  9. monster man
    Oct 20, 2003
    282
    Reno, NV
    no, FOR SURE, they rub if articulated, but if you're hella cheap and want to throw the tires on before the lift, just know that it will work in around town driving. I rubbed them maybe four or five times off road, but when it started I just slowed down and kept the wheel straight and it was fine. Could use a couple more inches behind the front tires as is
  10. chasone64
    chasone64 Registered Member
    Dec 15, 2004
    88
    Oregon
    Looks good. :D
    I need to do some trimming, cause I rub 39.5's with a 6" lift & 3" bl!!!! :confused:
  11. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    have any pics of this truck?
  12. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,030
    858
    Pinckney, MI
    I heard the 38.5 boggers only measure a little over 35 inches??? is this true
  13. monster man
    Oct 20, 2003
    282
    Reno, NV
    I know they're not 38.5", Interco even rates them at 38. I'll have to get my tape measure out. It has a lot to do with what rims they're on too, I would estimate these at 37 inches. They're much closer to 38.5 than 35, I know that
  14. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    The set i measured with 3psi in them were 37" tall, and that was with some wear and like i said, only 3psi in them. They definately do not only measure 35" tall.
  15. monster man
    Oct 20, 2003
    282
    Reno, NV
    just took a measurement on mine, 38.5x11's on 8" rims and they're at a 1/16th inch over 37. Like I said, not 38.5, but what tire really stands as tall as it claims when mounted? I bet off the vehicle they're 38 though, I noticed some sag when I let the jack down
  16. jekquistk5
    Jan 18, 2004
    11,030
    858
    Pinckney, MI
    My bad its the 38.5x15x15 that was smaller i think. I thought jerry(jk5) said they were only about 35.5" with 15 psi in them. I could be wrong though
