383 1 Piece Rear Main Flexplate, help me find one
Discussion in 'The Garage' started by sled_dog, Mar 25, 2005.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I'm having a hard time locating a 1 piece rear main flexplate for my 383. It is externally balanced. I need one to get my balance work done. Summit's new site is useless.
  2. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    This is the only one I've found so far. Not liking the $85. I don't need a freaking SFI approved one, its just a rockcrawler.
    http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=45247&prmenbr=361
    Alright answered my own crap
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7963764974&category=33616&sspagename=WDVW
    $40 is sweet but I don't know if I can wait that long on shipping. Have to decide quick. I'll probably end up buying one through the shop doing my work.
  3. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    ALL 1 pcs RMS flywheels and flexplates are externally balanced.
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    dude 1 piece 383 cranks are a dime a dozen. Eagle makes them almost as much as they do 2 piece ones. Not all 383s are cut down 400 cranks, aftermarkets do make specific 383 cranks you know. My crank cost me like $175, what an amount of money to blow :rolleyes:
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    actually no, its not.
    YUP!
    actually, its not any more expensive to build a 383 off of a 1pc RMS block anymore, crank prices are comparable.
    in 85 when they ditched the 2pc RMS, they also lost the ability to easily internally balance the engine as the 86+ sealing surface does not allow metal to be added or removed, so the flywheel/flexplate have to carry the weight.
  6. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I just bought a balance plate, thanks guys.
    And the reason for ther 2 piec block for me is factory roller camshaft setup and I had the block.
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    if you're running a 1pc RMS crank, not only do you not need the balancing plate, it physically wont fit, the bolt circle is different. you cannot buy a neutral balanced 1pc RMS flywheel or flexplate, they are ALL counterweighted.
  9. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Yep Beater_K20 is correct. When the 1 piece RMS came out all SBC's were externally balanced on the rear of the crank but not the front. I built a 383 using the 1 piece RMS and when i had it balanced it was a minimal amount of work to balance it using the factory flexplate.
