383/400 flexplate, different than 350?
Discussion in 'The Garage' started by sled_dog, Mar 11, 2005.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Is the flexplate different between a 350 and a 383? I know balancer is, I just bought my 383 balancer, but what about the flexplate? I was looking on ebay and some look like they have a weight on them and some don't(generic pictures?). So do I need a specific flexplate? All the ones on Ebay are 2 piece rear main and I need 1 Piece. The only one on Ebay that says 1 Piece says 350 and 383 in the title so who knows.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    In the early days of 383's we used 400 cranks , balancers , and flywheel/flexplates . Externally balanced .
    Nowadays with kits you can get it internally balanced for some money .
    If you need a 1 piece main piece its gonna be aftermarket or custom GM performance parts piece , 400's never came with 1 piece rear seal :k5: :k5:
    If you have an auto , you can use 14088765 12-3/4” outside diameter, 153 tooth, 10.75” bolt pattern straight from GM , was used on one piece rear seal ht383:D
  3. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    ha, I do understand that, there are plenty of companies making aftermarket ones. I'm looking for the info as to what aftermarket one I need. Mine is a new crank(Eagle 1 piece rear main cast) but its externally balanced(I should have ponied up for a Forged internal but I was stupid and went cheap).
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Dug one up and added above
    If you have an auto , you can use 14088765 12-3/4” outside diameter, 153 tooth, 10.75” bolt pattern straight from GM , was used on one piece rear seal ht383:D Today 10:01 AM
