383 & a stock TH700?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by meatloafK5, Feb 10, 2002.
  1. meatloafK5
    meatloafK5 Registered Member
    Oct 8, 2001
    53
    Lancaster PA
    Ok....one of the next projects on the Rust Monster, will be an engine swap. I was thinking of getting a 383 so that I can pull, tow, and offroad if I want to. The 305 that it came with is just about useless for anything I plan to do in the future, so I don't want to rebuild it. I even have the wife talked into a new Crate motor! My dumb question of the day.....will a 383 Crate hook up and fit/work well with a stock R700? My transmission is working great so far, and I would like to keep it. Thanks everyone!
    ...who knew working on a Blazer would be this addictive!
    84 K5 Blazer 305 with lots of rust.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Re: 383 & a stock R700?
    You will need a new flywheel for the 383. I did when I went to a 350 from a 305. Your 700R will hold up to a 383, but for how long I don't know. If you have a gentle foot, and a BIG tranny cooler it might last awhile.
    My Chevy isn't broken, its just out of gas.
  3. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Depends on power of the 383...what year 700 is it? Later models are a bit stronger and better sorted out. Also depends what shape it is in.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  4. meatloafK5
    Oct 8, 2001
    53
    Lancaster PA
    Hey thanks guys!, I have an '84 with a stock TH700. Sorry I was not clear. So far it's in pretty good shape, but it might need an overhaul for seal and such. I was looking at LMC for the flywheel, and they seem to have a bunch. Thanks!
  5. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    I had a friend with am 84 Suburban with a 383 and a stock 700, it was built, cam had over .500 of lift. Tranny lasted OK without a cooler, but then again that Suburban had enough power to smoke those tires forever. One thing I'd recommend is find a later model 700, like an 89-91 model or get a TCI racing 700 tranny. They're about $1,100, but worth the cash. If you must keep your current tranny, get an extra deep tranny pan and a large cooler. Even with this, the life of it depends on how you use the go pedal. More pedal, less life.
    Red 1989 GMC Suburban SLE V1500 - TBI 350, 700R4 w/ shift kit, Quad-shock front, 31/10.50/15 Pro Comp MT, 4.10 gears, Duals off cat
