383 ci in a 1990?
Discussion in 'The Garage' started by skelly1, Dec 13, 2003.
  1. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    Has anyone installed a 383 stroker SBC in place of the stock 350 with EFI? My 350 has 250K miles and is tired. I would like to rebuild it to a 383 with some cool cam, but not sure if it's worth it with a stock EFI system.
  2. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Yep. 383 w/MPFI, stock computer with a custom chip.
  3. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    Or do like im am about to, build a 383 with a 454 throttlebody and a custom chip from turbocity.
  4. skelly1
    Sep 2, 2002
    554
    San Diego, CA
    If you use the 454 TBI unit, is there anything else you will need to change? Will the 350 computer work for that too?
  5. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    Like ben427 you will need a custom chip for your computer.
  6. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    I believe you will need an adapter harness for the TPS switch.
  7. BigRed89
    BigRed89 1/2 ton status
    Oct 28, 2002
    223
    Los Angeles, CA
    You can use your stock 350ci TBI unit if you don't want to go out and buy a 454ci TBI unit. If you use the stock TBI don't go too radical on the cam. I used the 350 TBI on an '89 Sub and didn't have any problems. You will definitely need the aftermarket chip and Turbo City is a great place to have that done. Definitely consult with Turbo City and with the cam manufacturer of your choice as to what cam you should run.
