383 forged or cast?
Discussion in 'The Garage' started by 91GMCSuburban, Jun 13, 2005.
  1. 91GMCSuburban
    91GMCSuburban 1/2 ton status
    Dec 9, 2002
    318
    San Antonio, TX
    What should I do? What did you do? Pro's and con's besides cost?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Generally , forged is best , but most people never use the motor enough in a truck to warrant it .
  3. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    if your going over 6k rpm or 450 hp Id go forged but if not cast
  4. BAJA_BLAZER
    BAJA_BLAZER 1/2 ton status Author
    May 17, 2001
    517
    San Diego, CA
    Use Hypereutectic Pistons!
  5. 91GMCSuburban
    Dec 9, 2002
    318
    San Antonio, TX
    Why?
  6. 91GMCSuburban
    Dec 9, 2002
    318
    San Antonio, TX
    Based on calcs, 315 HP @ 5000 rpm, 485 ftlbs. So not high revving.
  7. Bhintz
    Mar 28, 2003
    1,341
    Roswell, Ga
    Ill 2nd that, only a 20 bucks more and hold power a lot better
  8. dyeager535
    26,979
    I believe this article came from Keith Black originally.
  9. gambit420s
    gambit420s 1/2 ton status
    May 17, 2005
    294
    KnoxVegas, Tennessee
    i believe that the extra silicon in a hypereutectic aluminum alloy allows it to be heat treated better and more closely matches the expansion rate of cast iron than forged pistons, because of this a forged piston usually require more bore clearance than cast, allowing for greater piston rock and shorter service life, but they are definately more suited to high hp setups albeit with less life
    my machinist put it this way for a sbc 350-400hp> cast or hypereutectic, 400hp<forged
    i just got 345np sealed power for a 350 and he said it was about perfect for my app(300ish hp, mild cam, low reving 350)
    now if i can only make it run..... :(
  10. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Forged crank if you're going to run more than 450hp@6500rpm. Probably get away with 500hp@6000rpm. The important part is to have it all balanced. You need to run ARP studs if you're pushing that kind of power.
    Forged pistons aren't really necessary unless you have forced induction or nitrous.
    Hypoeutectic pistons are kind of neat... they cost more but are actually more cost effective than regular cast pistons. Due to the cheapness of the metal and how the pistons almost always past quality control they're actually easier and cheaper to make. They're a far cry from a set of Wiseco forged pistons.
