383 info
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NoSmog73, Jan 23, 2002.
  1. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Would this kit be a drop in or will a 350 block still need to be taking to the machine shop and if so what would I need them to do..Here is the site but can't make the clickyhttp://speedomotive.com/383%20Mighty%20Mouse.htm thanks again mike
  2. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I bought a 415 rotating assembly from Speed-O-Motive and it works great, I highly recommend them. The block will need to be notched in the oil pan area. The longer stroke crank will need deeper notches to clear the counter weights. Since the 400 is externaly balanced you will need a balancer and flywheel/flexplate for a 400 CID chevy motor as well to complete the 383 kit. They clearance the rods for you in case your running an aggressive cam. They can also cermaic coat your pistons for a small additional fee.
    I started with nothing and I still have most of that left! - <a target="_blank" href=http://www.echobit.com:81/k5/> Pictures</a>
  3. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    oh, and the clicky <a target="_blank" href=http://speedomotive.com/383%20Mighty%20Mouse.htm> 383 kit </a>
