383 kit questions
Discussion in 'The Garage' started by CaveBlazin, Jan 28, 2004.
  1. CaveBlazin
    CaveBlazin 1/2 ton status Premium Member
    May 21, 2002
    1,348
    Middle TN
    Well I've found a 383 kit complete for $475 and its a great deal compared to some of the other kits Ive found but its got PBM parts I.E. PBM crank,PBM rods, etc.. Are these good parts and are any of you running these parts. Thanks
    Spence
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    when you say "kit" what does it consist of.. i was quoted 980$ for an Eagle fully balanced rotating assembly for a 385" stroker (400 throw and .04 over).. where are you getting the kit at?
  3. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Who is PBM? I never heard of them.
  4. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Ya....never heard of them. What comes in that kit? $475 is very inexpensive for a "kit". /forums/images/graemlins/thinking.gif
  5. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    Here is a complete list of the parts in this kit. SILVOLITE CLAIMER PISTONS H3426 in a -7cc flat top or (I also offer these in a dome if you prefer),HASTINGS MOLY RINGS 2M139,CLEVITE ROD BEARINGS CB663P,CLEVITE MAIN BEARINGS MS909P,MELLING HI-VOLUME OIL PUMP M55HV,FEL-PRO PERFORMANCE GASKET SET 92600,PBM PERFORMANCE CAMSHAFT non roller (your choice listed down below)PBM PERFORMANCE LIFTER HA817,DURA-BOND CAM BEARINGS CH8,PIONEER BRASS EXPANSION PLUG PE100B,PBM PERFORMANCE DOUBLE ROW 3 KEYWAY TIMING SET 700,PBM PERFORMANCE HYDRAULIC VALVE SPRINGS 3000 (1.250 OD 110#@1.700 300#@1.250 .500 LIFT),PBM PERFORMANCE CHROME MOLY RETAINERS 501S,PBM PERFORMANCE 7 DEGREE HD KEEPERS,PBM PERFORMANCE CRANKSHAFT 3.750 STROKE CAST STEEL 1 or 2 PIECE SEAL (SCAT CRANK)
    And here is the other kit for 100 bucks more 575
    (8) SEALED POWER PISTONS ,H-860-CP, HYPEREUTECTIC W/ COATED SKIRTS,"FLAT TOP" W/ 2-VALVE RELIEFS, (PRESS OR FLOAT PIN)
    (1) SET HASTINGS MOLY RING SET 2M-139
    (1) SET CLEVITE 77 ROD BEARINGS, CB-663-P
    (1) SET CLEVITE 77 MAIN BEARINGS, MS-909-P
    (1) MELLING HIGH-VOLUME OIL PUMP, M-55HV
    (1) FEL-PRO COMPLETE GASKET SET, KS-2600
    (1) SEALED POWER PERFORMANCE " SPEED PRO" CAMSHAFT, CS-179-R (DURATION @ .050 LIFT 222/222 ,VALVE LIFT .447/.447, 114 LOBE)
    (16) HYDRAULIC LIFTERS , HT-817
    (1) SET SEALED POWER CAM BEARINGS , 1235-M
    (1) SET PIONEER BRASS EXPANSION PLUGS, PE-100-BR
    (1) PERFORMANCE TIMING SET , 73017-3 ,DOUBLE ROW CHAIN,W/ 3-KEYWAY CRANK SPROCKET.
    (1) NEW PERFORMANCE 383 CAST IRON CRANKSHAFT 3.750" STROKE W/ 2-PC. REAR SEAL.
    (1) SET EAGLE FORGED I-BEAM CONNECTING RODS(5.700" LENGTH) SIR 5700-BB-LW "BUSHED" FOR FLOAT, OR SIR-
  6. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
  7. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    It would be interesting to know who makes the generic stuff in kit #1 that are listed as PBM. #1 does not list rod length. I am a bit sceptical, as their sight does not allow a potential customer to browse.
    Kit #2 looks fine. I would find a phone no. and have a list of questions ready, and give them a call.
    Check with the machine shop you are using, they might surprise you with one of their setups, as this is a popular motor these days.
    Whatever you do, with either of these kits, keep an eye on the RPM's, as their is no mention of 'good' rod bolts or even balancing of the rotating assy.
  8. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    I dont know, if that is legit they are makin NOTHING on it. I mean that crank for the big block (scat cast steel) costs $300. So assume $200 for the smallblock (couldnt find it on the site i looked) and you have 2xx left for all that other stuff. Kidna shady if you ask me.
  9. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    Dime a dozen parts, a cast Scat crank can be had for 179....
    Machine shop cost on those pistons probably is not very much either.
    I too am a bit sceptical....
    It can work....
  10. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    My machine shop wants 650 for the exact same kit minus rods and balancing. I even think some of the parts are PBM I think I might try it and if Im a winner on this the CK5 people will have a place to get good kits...But we all know what happens if Im a looser /forums/images/graemlins/smirk.gif O yeah and responding to however set something about the rod bolts I am gonna put some ARP rod bolts on it anyways never can be to sure. /forums/images/graemlins/thumb.gif
