383 or 406 sbc?
Discussion in 'The Garage' started by retroblazer, Mar 20, 2005.
  1. retroblazer
    retroblazer 1/2 ton status Premium Member
    Nov 30, 2003
    280
    148
    Gustine
    If you had a choice between these motors, which one would you want?
  2. tiger9297
    tiger9297 1/2 ton status
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    I have looked into a 383 and I know how you get to the 383 ci., but how do you get a 406???? I'm planning an engine build myself. I would be interested in everyone's input as well.
  3. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    No substitute for cubic inches - it's an old saying but it is so true......
    Actually build what is most economical for you - the 383 is very strong and the 406 only gets better .
    Tom
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Steamhole and heating issues with the 400 block are the only thing I'd say to keep away from them cause of. You can build a 383 out of a single rear main motor as well(I am right now) so that can be an advantage. 350 blocks are easier to find. For power if run right the 406 will be better.
    406= 400 block bored .030 over
    I'd build a 383 before a 406 myself... oh wait I am...
  5. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    A 406 in a minute. 383's are great motors, but not that impressive when compared to a properly built 406
  6. MarcS
    MarcS 1/2 ton status
    Oct 4, 2002
    515
    NJ
    A 383 is a torque monster. Dont know how much a 406 makes though. If the only difference is bored out 400, then I dont think it comes close to the 383.
  7. 1985K20
    1985K20 1/2 ton status
    Jan 11, 2005
    191
    Quebec,Canada
    heating issues is easy to fix with the 400 blocks...get that big triple core rad on there and change your thermostat to a 160 instead of a 195 and get good air flowing and your laughin:waytogo:
  8. akbound
    akbound 1/2 ton status
    Apr 20, 2004
    San Antonio
    406 in less than a minute. More cubes=more torque and more horsepower
  9. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    have to say you are wrong about that. A 383 is a 400 crankshaft in a 350 block. So thereby you have the same large stroke with a 400 + more cubic inches. Setup the same side by side a 400 will make more power, at midly different RPMs of course.
  10. tyco91burban
    tyco91burban Registered Member
    May 13, 2004
    33
    Northwest FL, Eglin AFB
    406 hands down
    as my daddy said "there is no replacment for displacment."
    of course he also said "speed cost money how fast you want to go"
    that is what i allways think of when looking at motor build.
  11. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    there are at least 2 replacements for displacement. Boost and Nitrous. Sure you will make more power with a bigger motor also running those but you can still get close to say a V8 power with the right power adder setup on a 4 cylinder. I wouldn't do it but its doable and I must respect that. There is a kid in my class who I think just about every other sentence out of his mouth is "There is no replacement for displacement" hearing that all the time has made me take a pretty good stand on the side of power adders on the subject. Of course the other sentence out of his mouth is "those things run hemis". STFU. Ok sorry that was pointless.
  12. MarcS
    Oct 4, 2002
    515
    NJ
    I stand corrected :D :D :D
  13. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    A two piece rear main seal 383 has a better chance of being more reliable. The lifter valley is thicker on this block than the one piecer....
    There is less chance of overheating a 383. Both can be built for about the same money....
    (I am doing a stock bore 400 myself)
  14. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    Working on a PFI 409 olds motor myself.....I get a kick out of a small block with >400 cubes. Keep em cool and don't over rev em and they'll provide a long life.
