383 or 454
Discussion in 'The Garage' started by unicknn, Jul 23, 2003.
  1. unicknn
    unicknn 1/2 ton status
    Jul 5, 2002
    138
    In San Diego now but Im from Texas
    I want to build an engine for my 87 K5. I want either a 454 or a 383 stroker. Which one would yall pick and why? Right now Im leaning towards the 383. I saw the power curve for a very strong 383 in the John Lingenfelter book and the torque was amazing.
    Nick
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  2. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    I would do either, depending on what I had laying around to begin with. Finding a good 350 block is easy, and all of your bolt ons will still work with it. BBC would require different brackets and whatnot. If you feel like spending the $$$ though, I would go BBC.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The 383 will cost less and will get better mileage, but the 454 will outpull it. Lingenfelter builds some amazing 383's, but it costs a LOT of money to make that kind of power. Last I knew, they got close to $15K for one of their high-zoot 383's. /forums/images/graemlins/eek.gif But their target market is the high end Corvette crowd, with bottomless pockets. When they want to go faster than one of their other Corvette buddies, they just call and order what they want. Lingenfelter's stuff isn't built with the budget racer in mind, but it does perform!
  4. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    I just finished a 425 hp 391 stroker build up for $3,500. You can built a 454 for a lot less.
  5. IronMan
    IronMan 1/2 ton status
    Nov 16, 2002
    223
    Bay Area, CA
    Be different and build a BB Cadillac engine! I will even sell you one! /forums/images/graemlins/deal.gif www.500cid.com
  6. Snarly
    Snarly Registered Member
    Feb 24, 2003
    6
    I have a 454 in an '82 K5. Lots of power, don't have to use high octane, have plenty of room for dual batteries and a large K&N. I don't regret the swap.
  7. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    454. A mild big block will still out torque a wild small block. and you won't have to go crazy with parts to do it. or rev it out at all.
  8. aj_johnson
    aj_johnson Registered Member
    Jul 20, 2003
    40
    and I just happen to have a 454 for sale right now for $900!! and it RUNS!!
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
  10. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    454 all the way, unless its a daily driver and gas mileage is a real concern for you. Cruising around the local beaches I can just idle around in the easy stuff, then if I need some speed I just floor it and it goes. I've got a friend with a *hot* 383, and he has to downshift and get some revs. With areas where you don't have room for a shift I walk all over him. An auto might make a little difference, but torque is torque and there is no replacement for displacement. I like the BBC because you don't need to rev the piss out of it, it'll run on crappy gas, and outpull a 383. Hell I still get 10+ miles per gallon.
  11. rigdonhome
    rigdonhome 1/2 ton status
    May 11, 2003
    252
    HoosierLand
    I second that!!! Caddy Power is the way to go... Enough Torque to reverse the rotation of the Earth, generally cheap to find and rebuild... Performance parts are expensive and limited, but with STOCK ratings like 400hp and 550ftlb of torque, who needs aftermarket parts???
    Sal
  12. aj_johnson
    Jul 20, 2003
    40
    i'm in Saint Anthony Idaho
  13. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    I have traveled this road before. My K5 has had a strong 350, a high torque 383 and it's present 427. My previous Suburban had the 500 Cad conversion done to it. I can only say that the 350 & 383 were the easiest to install (a bolt-in) but the 427 is the most rewarding when it comes to all around use. The Cad was VERY strong but expensive after market parts to build a bulletproof engine was it's downfall. I like the fact that for the most part it's just easier to find the needed parts for BBC.
  14. eldon519
    eldon519 1/2 ton status
    May 27, 2002
    161
    Kennesaw, Georgia
    Stock Cadillacs don't make even near the advertised 400 HP. It's more like 325 HP and 500 ft-lbs.
