383 stroker externally ballanced???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 3car, Sep 26, 2002.
  1. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    i was reading an ad for a 383 stroker kit and it said the motor must be externally balanced.huh?will it use the same harmonic ballancer it used before it was stroked?how about the flexplate? /forums/images/icons/confused.gif
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    383 stroker uses a 400's crank. Now isn't the 400cid small block Chevy externally ballanced ??? So it makes sence to externally ballance the 383 stroker.
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    The normal 383 stroker using a 400 crank, and most of the aftermarket cranks require external balancing. This means that you must use a 400 flywheel/flexplate, and a 400 harmonic balancer. There are some aftermarket stroker cranks avaiable that can be internally balanced. This means that you would have to pay an engine builder to balance the rotating assembly using mallory metal in the crankshaft counterweights, and this equals $$$.
  4. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    My 388 took both. When I had it balanced, it required Mallory metal and the externally balanced harmonic dampner. My machine shop welds a weight onto the flywheel mounting flange so that a externally balanced flywheel is not needed.
  5. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    thanks.that clears it up for me.
