383 stroker? questions on building one
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Silver84k5, Feb 13, 2002.
  1. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Can anyone gimme info on building a 383 stroker? Price? i heard its easy to do, anyone got one? you like it? thank you all
    If you dont make it the first time, Drink another beer, and press a little harder on the gas
  2. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
  3. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    I have built a 383 for my last blazer that since got stolen. yes they are easy to build and they make lots of torque if using the correct combination of parts. Scat actually now sells a rotating assmebly that should makes things even easier now. The 383 i had built for my last blazer consisted of a one piece rear main seal block with a scat crank and scat rods 5.7" and a set of KB pistons with 180 AFR heads. I had comp cams build me a custom hydraulic roller cam specs as follows .480/.487 lift at valve 206/212 duration at .050 on a 112 lobe separation. this combination using the tune port injection with other mods made 385 HP and 508 FT. LBS. torque. And considering i had 4.56 gears with 35's this made for a real stump puller. Hope this helps you make a decision to build a stroker
  4. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Thx man, lots of info, complicated sounding stuff heh but im sure its easier then it sounds, would my 850 Edelbrock q-jet be a good carb for it? cuz somone told me that my carb shouldnt be on a 350 they said its a bad combination, i dont know why
  5. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Yes, your 850 carb would be an ideal size for a 383 assuming you dial it in good along with timing.
  6. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    got any estimate on price? thx for your help
  7. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    price will depend on if you have to pay someone to do all the work or if you can do some of the work yourself. and also depends on what kinds of parts you intend to put in it. I am guessing from your name that you have an 84 blazer. You could always go to the dealer and buy the 383 that they offer, i have seen them for as little as 2,600.00 and as high as 3,700.00. it is a late model version using the one piece rear main seal block which means you would need to also purchase a new flex plate for your torque converter to bolt too since your old one would not bolt to the one piece rear seal crank.
  8. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    hmmmm... what if you wanted to take a 350 and fab a 383 out of it...
    All I know is it is a 400 crank.. I dont know much else but will a 400 crank fit without any machining of the block?
    I wanna do this to my 1991 9C1 police 350. It already has a roller cam/lifter setup but is only rated at 260+hp and 300ft lb of torque.... so I wanna bump it up a bit..
    thanks for the reading it is really good....
    <a target="_blank" href=http://community.webshots.com/user/rootbreaker>Pics of buildup</a>78 Chevy 3/4 - 14" on 40"x17x16.5 Ground Hawgs
  9. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    A 400 crank won't work with your '91 block. All the 400's used the 2-piece rear main seal. Your '91 has a one piece rear main seal. However, there are aftermarket stroker cranks that are made to fit your block, and without any maching on your part. [​IMG]
    To fit a 400 crank into a 350 block (that has the correct seal type) requires machining the crank, not the block. The main journals have to have 0.200 taken off of them to fit the 350 bearings. There is also some minor grinding that has to be done in the oil pan seal area of the block, to make certain that there's room for the rods to swing in their new larger arc. [​IMG]
  10. coloradoblazers
    coloradoblazers 1/2 ton status Premium Member
    Mar 2, 2001
    506
    WY
    Your best bet is to pick up a copy of "How to Build max perfomance chevy small blocks on a budget" by daivid Vizard, about $20 at barns and noble. I think I'm gonna build an engine similar to the #4 one that is featured. 383 ci, 425 hp, 450 ft/lbs through out the rpm curve. I want to find out what TPI would to to improve those numbers.
    K5- because size DOES matter!
    <font color=blue> <a target="_blank" href=http://www.coloradok5.com/gallery/Bucks-Truck>
    Fear This </a>
    </font color=blue>
  11. J.R.
    J.R. Guest
    4X4HIGH, im curious on other mods to your 383 to get that kind of power with that mild cam.. what kind of heads and what work done to them, and any other mods. was this a computer dyno or on a real engine dyno. i would love to build one with that kind of torque!!
    BIG BLOCK MAN
    "MORE POWER"!!
  12. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Just a taste of info for your knowledge, a 400 crank will fit into a late model one piece rear main seal block with the use of the rear seal adapter. This allows the use of two piece seal crank in one piece seal blocks. It does get a bit pricy though, around $130.00 i think.
  13. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    As i stated earlier, I used the AFR 180 heads which are 100% CNC ported from AFR. I also had TPI injection with 24.95 lb. hr. injectors and also a 1050 CFM throttle body which is the twin 58 mm one made by BBK. I also had an adjustable fuel pressure regulator set at 45 PSI at idle. The dyno info that i stated was using the dyno 2000 program which is pretty accurate to within 2%. I did have all the flow numbers for the heads I used along with all other pertinent information such as deck height and cylinder cc's, piston dish cc's, and combustion chamber cc's, along with compressed head gasket thickness and cc's. When inputting all of this information into the program it is very accurate.
  14. J.R.
    J.R. Guest
    is there a web site for the bbk injection system. i have been toying with the idea of getting an after maket system that can handle some real power. i like the ram jet system but not willing to put out 3 grand for it..
    BIG BLOCK MAN
    "MORE POWER"!!
  15. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    I know the crank is different for a 383, but what else is? I am pretty sure that the rods are different too. Does a stock 350 use 6" rods or 5.7"? I guess my question in other words in what else do I have to change in my 350 .030 over, to stroke it out?
    Thanks for the info,
    Mike
    The jeep eater ......[​IMG]
  16. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    I don't know if BBK has a web site or not. But as far as i know BBK doesn't do any fuel injection systems only throttle bodies.
  17. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Building a 383 can me done several different ways. You can use a stock 400 crank with the main journals cut down .200" and then use the stock length 5.565" 400 rods and a 350 piston, or you can use the stock 400 crank and the stock length 5.7" 350 rods with a special piston, or the stock 400 crank and a aftermarket 6" rod and special piston. When you build them with either the 5.7" or 6" rod you must clearance the rod bolts so that they don't hit the camshaft or use a small base circle camshaft. You must also clearance the block for the longer stroke at the bottoms of the cylinders so the rods don't hit there also. Naturally you will need to rebalance the whole rotating assembly. You may do so either externally or internally with mallory weight.
  18. BUDDY
    BUDDY 1/2 ton status
    Apr 28, 2000
    744
    Midland, TX
    Go here, <a target="_blank" href=http://www.sdpc2000.com/cart.asp?action=prod_detail&amp;catid=120&amp;pid=465>http://www.sdpc2000.com/cart.asp?action=prod_detail&amp;catid=120&amp;pid=465</a>
    Kind of spendy, but you can't beat the warranty or the 415 lb-ft of torque!!
    Buddy
    72 K-5, 33x12.5's, 350/350/205,12-bR,d44F soon to be 39.5'x15.5s, EFI502/nv4500/doubler205, d60F, d70R. Stay tuned.
  19. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    4X4HIGH brings up a good point, Rod length.
    To have a good flat torque curve use a 6" rod in your 350. This improves the rod/strke ratio and is realitivly east to do. In your case using a '91 block, a kustom crank of some sort sounds a bit pricy to me but i am poor[​IMG]
    -zakk
    World's Fugliest 1-Ton '77 K5
    [​IMG] CK5's Moab 2002 or Bust!! [​IMG]
  20. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    4X4HIGH... how much $ was that 383 w/ 508ft/lbs? torque is what i really want. and i would like to build my own motor.
    --Scott, 1989 GMC Suburban 2500 4" lift, 36" TSLs
    <a target="_blank" href=http://community.webshots.com/user/muddysub>http://community.webshots.com/user/muddysub</a>
