383 stroker questions?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wheelin247, Jan 25, 2001.
  1. wheelin247
    wheelin247 1/2 ton status
    Aug 29, 2000
    178
    hayward,ca
    hey what is the most power u can get out of a 383 strocker i have a buddy that has one and he has 340 horse power and 415 ft lbs at 3200 rpms ?.....is that alot for a 383 strocker or can u hace more power in the engine if u can what more can u do to it to make it more better ?
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Ho ya, I've seen stroker #s up in the high 400's for both HP and Torque!
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You can make way more power than that, but how much depends on if you want it to be streetable. With the right cam and heads, I'm sure that 700HP could be made with a 383. At least for a while... [​IMG]
  4. ut77gmc
    ut77gmc Registered Member
    Nov 29, 2000
    65
    Salt Lake City, UT
    These guys are right on. You can always make as much power as you want, but you always pay the penalty one way or the other (price and driveability).
    You should be able to make about 400 reliable HP (at the flywheel-If he's getting those numbers from the rear wheels, he's got a real monster and I want a ride!) and still be able to drive it everyday. Get a good low end type grunter/torque cam (Comp Cams Extreme Energy grind is pretty nice--but go with your favorite cam builder-same kind of pattern) and some decent flowing aftermarket heads (don't get the big hoggy ones--the smaller ports will build more torque--GOOD thing in our heavy beasts) with a solid built short block and you should at least be in that neighborhood, but reliable to boot.
    '77 GMC K15 LWB.....likes to get muddy
