383 Stroker
Discussion in 'The Garage' started by dammit32, Dec 8, 2002.
  1. dammit32
    dammit32 1/2 ton status
    Jul 20, 2002
    365
    Maine
    I've read alot on this board about how good a 383 stroker is for wheeling and has spurred my interest. However I currently have a 350 TBI engine in my 91 K5. Would I have to ditch the TBI to go with a 383? or is the TBI adaptable to a 383?
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I belive you can use the TBI on the 383. Might require a chip in the computer, but might not. I'm sure someone will know.
  3. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Yes its definately possible. Check www.thirdgen.org for info. There is a ton of stuff on there regarding TBI and hopped up engines.
  4. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    Yes it is adaptable, though on my 383 i upgraded to Multi-port injection, but used the existing Throttle Body, just ditched the injectors and bolted it on. Go for the 383, out of all the mods I have done to the Jimmy, the 383 is by far the best /forums/images/graemlins/pimp1.gif
  5. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    so whats involve in that? what do you have to do to a 350 to go 383? do your re-machine the block or something??
  6. Tshane
    Tshane 1/2 ton status
    Nov 26, 2002
    144
    Peoria, Illinois
    To make a 350 into a 383 first off u have to have your block punch out 30 over. then u have to get a 383 kit witch usually run from 600 up. that comes with cam, pistons, lifters, crank everything basically. the way you get the new stroke is by putting a 400 crank into a 350. witch takes your stroke from around 3.4 i think to 3.75 to 3.80.
    Here is one of those kits i was talkin about
    http://www.northernautoparts.com/ProductModelDetail.cfm?ProductModelId=1674
  7. dammit32
    Jul 20, 2002
    365
    Maine
    well i would get a long block. I think the kit would sit here cause I wouldnt know where to start with it lol
  8. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    For the cost of machining a stock 400 crank to fit in a 350 block, you're better off to get an aftermarket crank. Its a better casting, and you can get it with a one-piece seal for the newer blocks.
    383 longblocks are a good value, since they need a good (costly) balance job.
