383 stroker
Discussion in 'The Garage' started by b laub, Feb 2, 2003.
  1. b laub
    b laub Registered Member
    Nov 20, 2002
    45
    illinois
    when rebuilding my 350 to a 383 what all do i need to take into consideration, because its fuel injected i didnt know if i had to get a different chip or what because i dont' want to mess anything up???
  2. BigRed89
    BigRed89 1/2 ton status
    Oct 28, 2002
    223
    Los Angeles, CA
    As long as you don't go too wild with the cam, you won't have to worry about the computer and fuel injection too much. The 383 will be able to start and run with your stock chip with a mild cam. I wouldn't advise leaving it like that for a long time as your 383 will want more fuel and will end up running leaner with the stock chip. Once you have your engine built, have a shop burn you a custom chip for your vehicle. If you don't have a decent radiator and cooling system now, make sure you upgrade those things to be able to handle the increased power being produced by the 383. All the accessories from your 350 will bolt up to the 383, of course make sure you use a harmonic balancer and flexplate for a 400c.i. engine to match the 400 crank. Good luck and if you have any more questions just post them here.
  3. great scott
    great scott 1/2 ton status
    Dec 31, 2002
    333
    Utah
    I have a 383 in my wifes 88 c/k with the factory tbi and I love it. Along with tri y headers,mild cam,tbi spacer, flow master, no cat, mild port work, and jet 6 pack chip(not programed for a 383). We have been running it for 3 years and an estimated 50000 miles now it runs great but a bit lean. I have though about a bigger after market tbi but I dont want to trade off the 6 pack chip. I am at the moment bilding a 383 with holey projection for my dads jeep.
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    You should be able to get a chip calibrated for the extra cubes.
  5. b laub
    Nov 20, 2002
    45
    illinois
    ok that won't be to bad thanx guys /forums/images/graemlins/smile.gif
