383 what else??
Discussion in 'The Garage' started by CaveBlazin, Apr 3, 2004.
  1. CaveBlazin
    CaveBlazin 1/2 ton status Premium Member
    May 21, 2002
    1,348
    Middle TN
    Ok I start the engine building next weekend. I sent the block to the shop and had it clearanced for the crank,bored .030 over, cam bearings installed,freeze plugs installed and hot tanked. Any thing Im forgeting or any suggestions to add before it leaves the Machine shop?? Thanks,
    Spence
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    sounds like you got it covered. I'm sure they would have determined if it needed to be line bored or decked or whatever. Though I Guess decking would be a bit of your own preference, doubt you want some outrageous compression though.
  3. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    I assume you had the deck checked and main journals checked, block magna fluxed? Is this a 4-bolt or 2 bolt main? If 2 bolt get it set up for 4-bolt splayed caps. What about the heads? Any work needed there?
    Bill
  4. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Do you already have the pistons? I believe the block should have the bores finish honed to each piston, taking into account the type of material the piston is made of and which rings you will use....
    Have you had the rods checked/resized with new bolts installed? Did you go through the heads, checked for flatness?
    If you have the decks milled/cleaned up, you may have to get the intake done as well....
    CLEAN, CLEAN CLEAN and take your time with reassembly, check and re-check the clearances.
    Good luck /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif
  5. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Don't forget to get the engine balanced. That is a requirement for a stroker motor. You will need to take the crank, rods, piston, rings, bearings, harmonic balancer and flywheel/flexplate to the machine shop do have this done. /forums/images/graemlins/waytogo.gif
  6. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    Ok I have a 4 bolt main and I upgraded the bolts on the mains and the rods to ARP. Ok the machinist said it would be 200 to balance as long as my pistons were matched????? What does that mean then he said something about if there not it will have to be externally balanced (I thought it already was gonna be balanced that way). I am getting new valves for the head they are the 1.94 and 1.50 Im pretty sure at least /forums/images/graemlins/eek.gif Im gonna pocket port them, they have been checked for cracks and there good. Uhh I think thats it unless yall have anything else I should get the block back this weekend (I REALLY REALLY HOPE!!!)
  7. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    A 'matched' set of pistons is where the manufacturer has already gone through the trouble of giving you eight slugs that are already within 2 grams or so of each other.
    I thought that whether or not you balanced the rotating assembly depended on which crankshaft you bought.... /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif
  8. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    When they balance, they make sure every piston weighs the same which they should be 1/2 gram from each other. Then they make sure the big and small ends of the rods are within 1/2 gram of each other. They aim for the lightest component and take metal off the others. Then they take the combined weight of the piston and rod (with bearings, rings, and piston pin) and use that for the indexing weights on the crank when they spin it up.
  9. bigburban383
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Spence
    Make sure you get your camshaft clearanced too! They may have to take metal off the rods, or you may have to get a small base circle camshaft which also makes you have to get custom pushrods.
  10. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Don't forget some cams may hit the rod bolts /forums/images/graemlins/k5.gif
  11. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I got around that problem by using H-beam rods. Bling!! /forums/images/graemlins/woot.gif
  12. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    It is my understanding that because there are so many different rod and piston combinations available in the aftermarket, a 383 stroker crank cannot be "balanced" from the factory to account for the infinate weight combinations available. The instructions that came with my Scat crank, stated that the rotating assembly MUST be balanced. My crank even required a bit of mallory metal to balance correctly. /forums/images/graemlins/waytogo.gif
  13. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Torbo Charger, a little NOS and a six pack for the friends helping you out.......well afterwards anyway. When we are done with yours you can come over and help me. I have quite a large laundry list for the weekend as well.
  14. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    I would send them the whole works, but I see both internal and externally balanced cranks offered for the 400 sbc....
    I wonder if the same holds true????
    Now, back to our regularly scheduled programming....
  15. chevystepside
    chevystepside 1/2 ton status
    Sep 23, 2002
    147
    leadville colo
    have them torque hone the block. after they bore it .030
  16. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    It is hard to say if the same holds true for 400 cranks. I do know that if I was building an engine where I was mixing aftermarket and factory parts, I would definately have the assembly balanced. /forums/images/graemlins/deal.gif /forums/images/graemlins/waytogo.gif
