39.5 boggers on stock H1's?
Discussion in 'The Garage' started by GRAYTEXK5, Jul 24, 2006.
  1. GRAYTEXK5
    GRAYTEXK5 1/2 ton status
    Jul 23, 2002
    281
    Ft. Worth, TX
    hey guys, I recently got some H1 beadlocks...and I'm wanting to run 39.5x18x16.5 boggers. my question is, will these fit on the narrow H1s, or are they too wide? anyone have pics of a setup like this? I know I've seen 39.5", 42", and probably even 44" TSLs on them...but I know they're not quite as wide either, and I don't think quite as stiff? I think I remember something similar to this being asked before, and I did try a search, but...well, ya know...that was, less than successful. these will be going on a K5 that won't be a DD, but will be driven on the street some, if that makes any difference. again, pics would be great. thanks in advance.
    John
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    which rims are you using, early style 8 stud with mag run-flat or later 12 stud rims with rubber runflat ? some guys say the early mag style run flat will pinch the bead on 40" + tires if you don't cut it down. I run the later style rubber insert in a 38.5 tsl without a problem. I have never tried a mag insert
  3. GRAYTEXK5
    Jul 23, 2002
    281
    Ft. Worth, TX
    these are the 8 bolt style. if need be, I can always go with aftermarket beadlock inserts, if that's gonna be the only problem. I just wanted to know if the width of those boggers will be too much for that narrow rim.
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    some people on here run stock h1's with 44 boggers. you should be alright. 18s are hella wide tho. hopefully they will chime in
  5. resurrected_jimmy
    May 23, 2005
    2,241
