39.5 TSL fitment and suspension question
Discussion in 'The Garage' started by 88jimmyoungowner, Oct 9, 2002.
  1. 88jimmyoungowner
    88jimmyoungowner 1/2 ton status
    Nov 20, 2001
    425
    georgia-rome
    ok, we have an 81 blazer with a 6 inch lift, blocks in the rear. i want to fit 39.5 TSL's without triming past the inner fender. i also want to get rid of the blocks in the rear. how can i do this cost efficiently and effectivly? i know this subject has been beaten to death but i want to know because there is too much info on the subject to sort through. im not asking for opinions on how large of a ter or anything, just how much lift/trim and how should i get rid of the blocks?
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    both the links in my Signiture. that is exactly how you do it. no other way with the peramiters you set.
  3. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    I run a 3" bodylift along with my 6" and my 39.5's. I have a little trimming and I haven't rubbed yet but I'm sure if I tried to flex it out that it would rub the inners.
  4. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,131
    25
    El Paso, TEXAS
    with flex i had to trim a 6" to fit 35's---im just about to stuff 39.5's or 42's---i dont think there is any way out of cutting the inner fenderwells
  5. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Hopefully Boss will chime in on this but I believe his has about 4 1/2" suspention and a 1" body lift with 39.5's. I am getting mine ready for 39.5's with just 5" suspention lift and some minor /forums/images/graemlins/grin.gif trimming. I am going to get rid of the inner fenders up front and probably modify the rear wheelwells. /forums/images/graemlins/k5.gif
  6. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    When I ran 6" with 39's, I had to trim the inner fender up to the bolts and cut the lower back to the bottom bolt. Removed the swaybar and it hit under the most twisted areas.
  7. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i misread the question.
    yes, get rid of the blocks. if you all ready have 6" fronts, a shackle flip rear (ORD, Springer, Home-Brew, etc.) and soft rear spring will do alot.
    Extended front shackles from ORD move the axle forward a bit, and smooth out the ride.
    If you are REALLY rubbing, then try a body lift.
  8. 88jimmyoungowner
    Nov 20, 2001
    425
    georgia-rome
    so if i trim to the inner fender, do two inch springs, and ORD shackles, and zero rate add a leaves, then it will fit? i am trying to figure this out so that i can not have worrries when i do the axle swap and the tire swap. thanks.
