39.5's and 64's on! pics
Discussion in 'The Garage' started by muddybuddy, Jul 18, 2006.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    got the tires mounted yesterday and finished up the 64 swap this morning. it consists of a home made shackle flip, with eibach lower shackles (6.5") and 5" procomp 64's. we moved both brackets, so the axle was pushed 2" backwards. i did a flex test behind the local safeway (on the loading ramp) and all i can say is wow! i didnt even get to max it out, and the front springs didnt do anything. unfortunately i didnt bring the camera with me, but a friend took pics on his fone and is going to send them to me, so ill post them up when i get them. it also rides much better. i couldnt be happier with the results. tell me what you think
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Looks good. I told you those springs were soft!!!
  3. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    they are! at first they were really arched, then when they were on the truck you can see they are almost flat.. im hoping to swap out the front soon as well.
  4. liv24wheel
    liv24wheel Registered Member
    Jan 20, 2005
    64
    Albuquerque, NM
    What are those springs off of? And where did you get those? How much lift do you have with that shackle flip and 5" springs?
  5. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
  6. b454rat
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Depending on how much lift your springs give me, I might get another set of those. Maybe with the extra weight of my motor and a winch they will flex a little more. Should have kept the ones that I had, and got smaller ones for the front.
  7. orangebeast74
    orangebeast74 Registered Member
    Jul 27, 2002
    22
    Fresno CA
    How far forward did you move the front mount and how far back did you move the rear mount?
  8. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Things i noticed...
    1. Nice shackle angle
    2. The stock lower brace for the rear shackle mount should either be Moved under the bracket (unless theres bracing there) If there isnt it definetly should be! If there is a brace there that was added in then it just looks hack leaving the stock one there
  9. liv24wheel
    Jan 20, 2005
    64
    Albuquerque, NM
    Are you running a CV driveline?
  10. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    there is currently no bracing behind the rear shackle mount. eventhough its completeky welded on there, you think thats necessary? i guess it doesnt hurt to put one behind it.
  11. k5 krawler 50
    k5 krawler 50 1/2 ton status
    Jan 26, 2004
    1,467
    Gardnerville, NV
    looks good man, keep up the good work..
  12. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    that's looking VERY good!!! Are you running a CV shaft in the rear? Had any problems with vibes? I dont' have the money for a cv rear shaft, but my pinion is pointing way up, so I ordered some shims.
  13. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i do not have a cv shaft yet, but i just bought a 241 and will be doin a sye on it then a cv shaft. with the regualr shaft, there isnt all that much vibes surprisingly. so far i havent had any axle wrap, but if that becomes an issue ill make a trac bar
  14. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    is your pinion pointing straight at the t case, or kinda pointing above the t case??
    I haven't driven mine yet, but I'm wondering if I should have even ordered shims at all :doah:
  15. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    its pointed almost directly at the t-case, thats just how it happened after the flip. before it was just parallel with the ground, the flip really does alot for the pinion angle.
  16. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Looks good but please brace that rear shackle mount :crazy:
  17. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    ill brace the rear mount, i wonder if its worth tryin to reuse that stock brace or just make a new one
  18. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Forget the stock one go all out and make a beefy one :D
  19. 79k20350
    Nov 22, 2004
    7,757
    Ct
    x2, it shouldnt be that hard, and you definetly need something ther to tie it in better to the underside of the frame...
  20. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    alright thanks for the input. ill get a support made and put on :)
