396 BBC in a first gen
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by aksidentproan, Apr 5, 2002.
  1. aksidentproan
    aksidentproan 1/2 ton status
    Dec 8, 2001
    477
    Maryland
    How difficult is it to fit a 396 in a first gen blazer? Thanks
    Evan
  2. SnowNuts
    SnowNuts Registered Member
    Apr 5, 2002
    48
    Detroit ,U.S.A. HOCKEYTOWN
    My first chevy trucks that I got hooked by were stock BIg Blocks..The 70 Chevy Cheyenne had a 396 factory bored 30 thousannths over with all TRW parts which made it a 402. That truck had a Muncie four speed in it and from a 10 mile an hour roll not much could touch it. The next truck was my first Blazer & it had the same 402 with the automatic & it rocked also but in the mud! The big block parts are out there but people don't like to let the original stuff go . GOOD LUCK
  3. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    I don't know how HARD it was.....but that's what the P.O. put in mine! It's stroked to a 427, but it's based on the 396 block. From what I've been told, the 396 uses the small block motor mounts (like the standard 350s) so there's nothing weird about that part of the conversion.
    The only obvious problem might be the clearance between the valvecovers and the firewall. That's pretty "tight" on mine.
  4. aksidentproan
    Dec 8, 2001
    477
    Maryland
    Greg - Do you have a body lift?
    Evan
  5. Crushergmc
    Crushergmc 1/2 ton status
    Mar 17, 2001
    181
    Oregon
    The 2wd did come with different motor mounts for the big block. Not sure about the 4wd but I think they were different to. I'll ask the question on www.67-72chevytrucks.com and I'm sure someone will know.
  6. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    Yep...... 2" Body Lift
    That makes a difference too.....REAL important, I should have remembered that too.
  7. Tommy
    Tommy 1/2 ton status
    Feb 21, 2000
    260
    Alabama
    I bolted my SB mounts to my 427, bolted it right in, oh yea, did have to modify the crossmember a bit to clear the oil pan. Nothing like a BB grunt!
  8. SnowNuts
    Apr 5, 2002
    48
    Ya gotta love bigblock grunt & nothin will push you thru mud like all that torque. I just paid $1500.00 for a 72 blazer that has afresh 350 in it with a new Edelbrock intake & carb so I will see what tha same setup will do with that ...RPM vs Torque here I come!
