396 motor
Discussion in 'The Garage' started by 79Stomper, Nov 16, 2004.
  1. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    I want to add a little spunk to my truck and well I have found a 396 but I have never heard of anyone running one and have no experience with them as to their origin of vehicle or the reliability of them. Guy had it in a car he use to race at the local strip and pulled it out and has been sitting in the garage for about a year. Said it was putting out about 500 at the crank when he opted for something more. If I get it plan on doing a rebuild and freshen everything up before it goes into the truck. Let me know what you all think of them.
    James
  2. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    Chevy trucks had the 396 as an optional engine for two years only, 1968 and 1969. Not sure on the car version. If the price was right I'd get it.
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Have you heard of the 402 Big Block ?? Same engine as the 396. Chevy bored it at the factory .30 over (I think) too get over 400 cubic inches out of it. I like the 396. Not as much torque as a 454, but still a hell of a motor. IIRC, you can drop a 454's crankshaft in it and you'll have a 427. Or is it a 396's crank in a 454 for the 427 ??
  4. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    Yup, that one.
  5. chevy_muscle
    chevy_muscle 1/2 ton status
    Mar 16, 2004
    103
    Murphy, tx
    396's were also used in chevy cars from '65 - '70.
    the 396 is great for higher RPM applications but as said, not as much low-end torque as a 454. .... the classic trade-off.
    Ya just gotta decide what RPM you want to turn your engine at.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yep, agreed. The 396 is the "short stroke" big block. It's still a 3.75" stroke. To say it is low on torque is kinda silly when it has the same stroke as a 383 that everyone thinks is a torque monster, and the heads flow better!
  7. 79Stomper
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Cool, thanks all. I believe I am going to go ahead and get it. For 150 bucks couldn't hurt that much. I just want a little more than the 350 I have in there now.
    James
  8. diesel4me
    Jul 24, 2003
    17,568
    943
    Massachussetts
    The 396 came in several versions,from a wimpy 2 barrel one in 1969,to a 375 hp screamer in camaro's and vette's--one of the scariest rides of my life was in a 69 GTO a friend of my brother had with a 375 hp 396 out of a 69 chevelle in it--we went down a rural 2 lane road with a 35 mph speed limit,from a dead stop to over 110 mph in 3rd gear within an 1/8 of a mile or so--and it was just starting to open the secondarys on the 750 holley double pumper! /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif--I asked him to let me out--I'm no wimp,but I have no death wish--didnt want to see how fast it would go in 4th!.He'd had a few drinks,and I didnt want to be a statistic,so I walked home and changed my shorts--and smoked about 10 butts on the way home,trying to get my heart rate back to near normal!. I have ridden in a few other 396 powered cars and trucks that were pretty doggy too though,the 69 2 barrel one a friend had in an impala would hardly spin the tires with a powerglide tranny--I guess its all in the compression ratio,heads,and cams that determine how scary it will be--- /forums/images/graemlins/thinking.gif /forums/images/graemlins/grin.gif
  9. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    I'm running a 402 in my '87. It's fairly mild but has more power than I'd care to use on the street. Probably generating ~400 HP.
    Port matched dual plane edlebrock manifold
    Pocket ported milled heads w/ dual valve springs. ~9.2 CR
    Hyd. roller cam split pattern ~.510 lift
    Thorley tri-y headers
    Holley 750 vacuum secondary
  10. 79Stomper
    Mar 4, 2004
    4,225
    19
    Forest, VA
    So this thing would be considered a big block of some sorts?
  11. rcamacho
    Jul 1, 2004
    1,324
    WA
    396 BBC 30 over.
  12. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    i run a 30 over 396 with closed chamber 427 heads in my Chevelle.. solids help out its low end torque a bit.. good motor.. i've heard they grenade easier than the 454's, but mines been awesome..
  13. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] Yes, the 396 is a Big Block Chevy engine.
  14. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    I have a 396 big block in one of mine. In it's day, it was a strong runner and pushed a longbed crew cab on 39.5" Boggers and 4.10 gears around without much problem. It definitely was a motor that liked RPMs (for a big block), especially with the cam that was in it. When it came to heavy towing, it just didn't have the torque that a 454 did, especially when it dropped below it's ideal RPM range.
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    A double pumper has mechanical secondaries. They were open the minute he stomped it.
    As with any engine, cylinder pressure is what creates torque. As you stated, different head/cam combos can make a tremendous difference.
  16. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    A 396 has a 3.76" stroke....
  17. k10clown
    k10clown Registered Member
    Nov 10, 2004
    44
    Warren, Michigan
    A 396 is a hell of a motor. I swaped one in a 1979 chevy 1/2 ton short box. I went through 2 transmission and a rear axle before I ran into Jonny Law and had to get rid of it. /forums/images/graemlins/deal.gif Do you know what the motor came out of?
  18. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    hope there is nothing wrong with it if all he wants is $150 /forums/images/graemlins/dunno.gif
  19. diesel4me
    Jul 24, 2003
    17,568
    943
    Massachussetts
    The point I was making is he DIDNT stomp on it!--He gradually pushed it slowly to the point where the secondaries were starting to open!--I thought it WAS already floored!--thats when I decided it was time to get out and walk! /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif.I've had some other fast rides,but I dont recall ever being that scared since!.I've had 3 454's from the smog era (73 and 74)but they were dogs compared to that 396 he had. /forums/images/graemlins/crazy.gif
  20. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    for 150?? I'de be all over it like flies on S*$T!!
    But, before you put it in your truck, you might want to research it and see what it came from. Oval port, or rectangle port heads? Some of those early 396's are worth alot to the right buyer! a resto guy would pay alot for the "right" block. enough to build a 454!
    I was trying to find the "correct" block for my 69 vette. a 427 tripower car. 12 years ago, it was 1,500, for a BARE correct block.
    Hey, you never know what you can get!! Just a thought!
    either way, a GREAT buy.
