39's too much for 3/4t?
Discussion in 'The Garage' started by SS66, Oct 15, 2003.
  1. SS66
    SS66 1/2 ton status
    Feb 13, 2003
    538
    WI, USA
    39\'s too much for 3/4t?
    Can a 3/4 ton stock Suburban's drivetrain handle 39's? Or is a 1 ton upgrade a needed thing.
    Thanks in advance
  2. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Re: 39\'s too much for 3/4t?
    I would say it depends on how often you run it in 4wd.
  3. SS66
    SS66 1/2 ton status
    Feb 13, 2003
    538
    WI, USA
    Well.. lets just say.. 30 percent of the time its in 4WD.
    And boy that was a very fast response.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I broke my 3/4 ton front with 38s, some have managed to do it with smaller tires than that.
    I'd say depends on engine size, locker or no, right foot, and what the intended wheeling is going to be. For just driving I'm sure it'd be fine.
  5. SS66
    SS66 1/2 ton status
    Feb 13, 2003
    538
    WI, USA
    Alright. Thanks!
  6. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    I ran trails with 3/4 ton stuff and 39 boggers. i had a locker in the rear was very smart with the skinny pedal...never broke a thing...
    its all in the application and the driver
    Later
  7. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    burbs are very heavy... so are 39.5s. personally, I wouldnt run them on a 3/4 ton rig. the rear axle wont be a problem, but its prolly a matter of time with the front if u wheel it hard.
    j
  8. bigredblzr
    bigredblzr 1/2 ton status
    May 9, 2003
    151
    NORCAL BABY
    It may also depend on what year 10bolt it is. The later 10bolts are significantly beefier than the early ones. Even if it is one of the stronger ones, I wouldn't lock it!
  9. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    oh, another thing I didnt think to ask... what tire/wheel combo u plan on running? i mean, if its some heavy azz 1/2" steel-centered rims plus beadlocks and 39.5 Boggers thats one thing... if its some super light forged aluminum rims + 39.5 Iroks... thats something else. sooo, whatcha gonna use?
    j
  10. chubbybob
    chubbybob 1/2 ton status
    Oct 18, 2002
    730
    think about how many jeeps you see running around on 35s with those little baby axles they brake axle joints often if they wheel it hard but its quick and easy to replace those things. its all about how you drive it you can still wheel it all you want but know when not to hit the throttle.
  11. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    jeeps weigh a lot less than a fullsize chevy, thats why they can beat on 1/2 ton axles and they survive (for the most part).
    j
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    For most Jeeps, a 1/2 ton axle would be an upgrade compared to what they come with.
    Me personally, I can't wait to have the '60 in. I don't like being easy with the skinny pedal. There's a reason I've got strong driveshafts and a rev limiter. I like to hold it to the floor. I am not stupid, but I do enjoy some throttle action, as do all of us. I don't want to worry every time I put the hammer down, so I'm swapping to 1 ton stuff.
    I'd say that 1/2 ton stuff can continue to be used with a set of 38s in mud only, but it WILL break, just be prepared to fix it.
    I personally don't want to work on a truck in 3 feet of mud, so I want my stuff to stay together.
  13. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    First, if its a 100% street rig... I'm sure it will do alight... BUT if its a trail rig...
    Traction and vehicle weight is what its all about. If your K5 has undergone a SERIOUS diet, and weighs less than a normal rig, MAYBE you could do it for a season.
    A normal K5 with a serious driver seeing 3-5 trails... NO WAY IN HELL. Tell me all the stories you like, but I've watched a 3/4T rig on 39.5s TRY to make it a season on a BUILT 44, and he just couldn't keep it together.
    I'd go smaller if you don't plan to upgrade your axles inside the life of the tires.
    -Dan
  14. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Quick and easy to replace axle u-joints, or did I read that wrong? Last time I checked it was a PITA to change a axle u-joint, have to dissassemble everything from the spindles out, thats not fun nor easy. And I don't wanna hear I can do it in 20 minutes, no f-ing way /forums/images/graemlins/grin.gif
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I can do it in 20 minutes, but I don't have an unlimited supply of axleshafts, nor does anyone else I know, and any time I've seen them break, they typically take the shafts with them.
  16. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    I have to add my 2 cents here If you are carefull they will live get some spare front shafts cause you will probably break some. I have 38s on 3/4 ton stuff I assume I will break one sometime but I havent yet. I don't have a locker in the front. Poeple told me you couldn't run bigger than 31s on my zuk I beleived them for a while and then said screw it I have had 33s and a front locker for 7 years now and have only broken 4 or 5 axles in the front and I do wheel it hard. Rocks mud jumping it out at the dunes etc. So if you really want 39.5s go for it. Nuff said /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  17. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    So let me get this right, you can jack up your truck, take off the tire, dissassemble the hub, remove the hub from the spndle, remove brake caliper, remove the spindle and backing plate, remove the axle shaft, replace a u-joint or axle shaft assembly entirely, then put it all back together CORRECTLY as in properly torqing everything and setting up the wheel bearing properly...in 20 minutes? And then you can do all this in the dirt, on a trail still in 20 minutes?
    I call BS! /forums/images/graemlins/grin.gif
  18. steelsoldiers
    steelsoldiers 1/2 ton status
    Oct 17, 2002
    365
    Charleston, West Virginia
    Sometimes it takes me 20 minutes to chase that damn internal snap ring around the inside of the hub with a greasy screwdriver until I can catch one edge with an awl and pop it out. I hate that snap ring /forums/images/graemlins/angryfire.gif
  19. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I call BS also...It can be done in 20 minutes.. But not correctly...
  20. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Last time I did a stub on the trail about a month ago... it took about a hour... with air tools (Thanks Todd!), and MANY hands helping. We took our time a little, but we got the job done - I wheeled the rest of the day! /forums/images/graemlins/thumb.gif
