3in. body lift for 1 Ton truck?
Discussion in 'The Garage' started by 86Cucvbeater, Nov 9, 2005.
  1. 86Cucvbeater
    86Cucvbeater 1/2 ton status
    May 24, 2005
    428
    north carolina
    Anyone know who makes one? Everywhere I look says 1/2 ton or 3/4 ton except for ORD but their kit is only for 1 in. Anyone with an actual 1 ton used one of the 1/2-3/4 ton body lifts? Any insight would be appreciated as I need the clearance to fit the 44's I just got. :p: Thanks
  2. BlackMesaOffroad
    BlackMesaOffroad Registered Member
    Jul 18, 2005
    16
    OK
    Performance Accessories makes them and we carry them. :D
  3. 86Cucvbeater
    May 24, 2005
    428
    north carolina
    Thanks, PM sent.
  4. 86Cucvbeater
    May 24, 2005
    428
    north carolina
    Ok, now I've found a kit for my 1 ton but supposedly it wont work because I have a diesel engine.. WTF is the difference? Anyone?
  5. sweetk30
    Nov 1, 2004
    25,547
    542
    horseheads , ny 14845
    yep got one in this truck hear 1 ton 4x4 with the 1/2 and 3/4 ton kit.
  6. 86Cucvbeater
    May 24, 2005
    428
    north carolina
    any issues doing that? and is that 2 or 3 in?
  7. sweetk30
    Nov 1, 2004
    25,547
    542
    no problems as its gas and 3" kit with gap gaurds also just not in in the pics. poped in with no problems to speek of as it was a supper clean truck to start.
  8. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I found some 3" bodylift spacers at the boneyard. I cut them down to 2" and put them in my 1-ton. ;)
    I had to notch the floor maybe 1/2" for the 205 shifter.
    The only real problem was the rad shroud. I ended up removing it, and as a result, it would overheat when crawling around on uphill stretches. I suspect this would be a problem for diesels.... I'm sure losing the shroud (on that monster radiator) would impact the cooling much more than on a gasser.
  9. ramses
    ramses 1/2 ton status
    Jul 2, 2004
    238
    West Virginia
    SweetK30, what size lift and tires are on that truck? Do you have any more pics of it?
  10. sweetk30
    Nov 1, 2004
    25,547
    542
    all the specs for it are in my profile. and what pics do you want? pm me on this one.
