3in body lift probs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazer4evr, Oct 10, 2001.
  1. blazer4evr
    blazer4evr Registered Member
    Oct 8, 2001
    5
    dallas, tx
    I was putting a 3 in body lift on my 86 k5 and ran into a couple of problems. i need to extend/ modify the transmission/t-case linkage and don't know how. any info is useful.
    thanks
    kevin
  2. those kits usually have a 3" piece of stock to weld onto you existing shaft to make it long enough.
    [​IMG]<font color=red>BigBurb[​IMG]
    <font color=purple>I Like my Burb'n on the ROCKS !!
    <font color=black>Imported to Kentucky through military channels !!
  3. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    yup, you need to weld a 3" extension on to your shift linkage (assuming you have an auto), and as far as the t-case goes, mine adjusted using the adjuster on the t-case linkage. the lever is mounted to the body, but the linkage itself adjusts w/ nuts. crawl under and look, its actually pretty easy.
    the body lift kit should of came w/ the extension for for tranny, but a piece of rod of similar size will work.
    good luck rob
    350 TBI, 700R-4, NP241, D44-14FF, 4:10's, 38.5 TSL/SX's, full conv., full cage
    <a target="_blank" href=http://www.yeild2me.rockcrawler.com>www.yeild2me.rockcrawler.com</a>
  4. flblazer
    flblazer 1/2 ton status
    Nov 24, 2000
    149
    tampa fl
    send me a pic of b 4 an after i want to put 1 in mine right now i have a 4" an i am lookin to put a 3 body
    can some 1 find me a ford i need to take a pee still peein on that ford just have to keep goin dam i can not stop pissin:) k5s kings
  5. blazer4evr
    Oct 8, 2001
    5
    dallas, tx
    thanks a lot that will help. also is there anything i should know about the heater core when i lift it? i tried lifting it already and antifreeze leaked all over my floorboard. just wondering
  6. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    You may have a dry rotted core line and when you lifted it, it went ahead and cracked open on ya. You may need to get some more hose (longer) adn replace it.
    Surgeon General's Warning:
    Viagra and steroids may be harmful to your spouse![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
