3inch Body Lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rebel-Rider, Mar 11, 2002.
  1. Rebel-Rider
    Rebel-Rider 1/2 ton status
    Sep 30, 2001
    134
    North Dakota
    I just found a trailmaster 3 inch body lift and i was wondering if i put it on what are some of the other things that i would have to change (brake lines etc...) and how much would these things cost
  2. 87GMC
    87GMC 1/2 ton status
    Nov 5, 2001
    653
    Olathe, KS 66061
    Going to need brackets to lift you bumpers also if you want them to match the body. If you brake lines are coiled near the master cylinder, they should be long enough. Probably need to cut to bottom of you fan shroud to clear the fan. May need to change upper radiator hose. May need to extend or alter shifter linkages.
    BTW, fill out you profile so we know what you are working on.
  3. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    on a blazer I needed....
    2 longer bolts... the fubar'd my kit...
    Had to extend the tranny shifter... included..
    I extended the xfer case shifter...
    Took off bottom of shroud...
    Retied up some wiring...
    you may have to do something with your gas tank hose... but should be ok...
    Oh make sure you do one side at a time... sucks sitting croooked all the time...
