3inch drill bit
Discussion in 'The Garage' started by tecton, Dec 13, 2003.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    need a bit to drill a 3inch diameter hole in soft very thing steel
  2. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    Hole saw. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  3. tecton
    Dec 1, 2002
    1,553
    WV
    no no no
    drill bit /forums/images/graemlins/rotfl.gif
  4. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    The biggest twist drill bit I ever saw was 2".
    You can risk ruining a forstner bit which will cost you around $80. I've got a 3.5" one for doing plumbing. Otherwise you can get a high quality hole saw (Starrett) for around $15 and another $11 for the arbor. I've had pretty good luck with these.
    What are you cutting?
  5. TJS
    TJS 1/2 ton status
    Nov 13, 2001
    179
    Westport,CT
    There is a tool called a trepanning tool that is used in the machining industy. It is called VAL-CUT trepanning tool made by SPI. They will fit a drill press with a 1/2" shank.
    They are hard to find. You need to get them from a good machine tool supplier. The part number you need is 80-001-1
    it is 159.00. I use this on my BPT machine. It makes nice custom washers too.
    T.J.
  6. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    If not a 3" bit, hows about a torch? /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif Seriously though, how about a jig saw, with a circular, scrolling attachment? Or even a sawsall.....
