3rd gear popout (420, 465) A very good explanation as to why this happens.
Discussion in 'The Garage' started by BigOrange90Jimmy, Nov 6, 2003.
  1. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    This was taken from a post on North Carolina 4x4 forum.
    "SM 420s like to wear out the shift rods and fork assemblies long before the gears and bearings are gone, especially if Billy Bob driver liked to hang onto the shift lever like a grab handle as he went 'round corners. The detent balls wear the lands on the rods leaving a depression rather than a true detent and the shift forks wear to the point of sloppiness, failing to fully engage the gears. Try that first, it's a relatively cheap fix if it works and you're ahead on the parts if there's more to do. Be aware that if the detents are really worn, there'll be more stuff that needs attention."
    I just figured you guys wouldn't mind me posting up this good piece of info.
  2. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    A worn out input bearing will also cause that. We had problems with the 420 in my dad's jeep. We finally replaced that bearing after pulling the tranny about 5 times. So far it's still working like it should.
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
  4. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    welcome back! /forums/images/graemlins/thumb.gif
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    He's not coming back he just always lurks in the backround.
