3rd grade math help needed, maybe 4th grade
Discussion in 'The Lounge' started by newyorkin, Feb 2, 2006.
  1. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Nah, just kidding. :D :D
    I do have a math question, though.
    I need to figure out a formula for excel. I've had one running quite some time, but I did a little fiddling with it today and noticed under certain conditions, the output is screwed up... So can any calc gurus help me out if you have a minute...?
    I will call them by column letter for simplicity's sake.
    Right now, the formula reads:
    (N*M)+(P*O)-(C*L)=?
    Looks pretty simple, right? Well it's not with all elements involved.
    N, P, and C are unit prices that can vary. M, O, and L are unit quantities (always equal or less than D, not in the formula).
    L should always be the sum of O and M, and eventually equal D (not included in formula).
    Sometimes O and P are ~0~ and M is simply equal to D, making L and M equal.
    Sometimes M is less than D, but the values for O and P are not yet received (which makes thier and L's values ~0~), and a calculation needs to be made. The result is then incorrect.
    I know some of the data is redundant, like D and L, but this is to allow an external script to read the sheet and compare those numbers to determine first, second, or final sale.
  2. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Nevermind, got it. Anyone want to try to figure it out anyway? :D :D :doah:
