4:1 conversion for my 203........or something similar for an upgrade
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by twenty_below0, Jun 4, 2002.
  1. twenty_below0
    twenty_below0 1/2 ton status
    May 16, 2001
    436
    Haines, Alaska ...u.s.
    OK, getting ready for the conversion this fall to 1 ton and want to find a kit for what I have, do they make one and how much 4:1 or something close, how difficult are they to install. of course the doubler is an option but would rather convert my 203.....always up for change though /forums/images/icons/smile.gif
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    It is a 1,000 plus your front half as a core. They have to machine the case to make it fit. I believe the company is Wagoneer Machine or something like that.
    Dan
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
  4. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    its only 3.6, but for a grand im not sure its worth it, Id go with a double better gear selection and it might be cheaper but i dont know much about the cost for the doubler.
  5. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    I heard that they have switched to 3.1:1 due to clearance issues with Ford cases. With a Doubler, you would have 2 choices for low. The cost for a Doubler with driveshaft mods will probably run more than the Wagoner conversion. But, you would have more options, including 2 wheel low.
