4.10/4.11 gears
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Stephen, Jul 2, 2001.
  1. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    This was brought up in another post and rather than continue it, I brought it here.
    You're welcome Steph......:-)
    when they build diff gears, you can end up with different numbers of teeth on the ring and pinion that still come out close to the "target" ratio. A lot of trucks will have 4.10's in one end and 4.11's in the other, or even 4.09's in one or the other. That's about as far as it goes though. You won't find them separated by much more than that.
    The old tale about having one set in the front different so that it "pulls" really isn't true, it just happens that way. And to be honest with you, you'll notice a difference in tire pressure between front and rear before you notice a difference of .02 in gear ratio.
    Making the world better, one truck at a time.
    [image]http://coloradok5.com/logo_ordsmall.gif[/image]
    SW-ORD
  2. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Thank you Stephen, I appreciate it... I guess you learn something new everyday! Wes (thatk30guy) also helped me clear it by saying the difference can be up 2.99% and still be fine.... so that makes sense now. [​IMG]
    By the way I just ordered my brace from you yesterday... I'll try it out at Hollister! Woohoo! [​IMG]
    I removed my quote so gay, vegetarian, minority, eco-nazis who love Jesus, nuke spotted owls, vote Gore and smoke medical marijuana won't be offend.
  3. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Thanks for making that clear...
    <A target="_blank" HREF=http://community.webshots.com/user/vwryda>http://community.webshots.com/user/vwryda</A>
  4. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Yep, that is one of the top ten boogers of mis-conception. Very good point Steve. I've seen hints of this around but have always failed the energy test to respond.[​IMG]
    HELP! I'm under my truck and I can't reach my beer![​IMG]
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  5. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    So, do you think I should go with 4.10's or 4.11's? I'll probably be a lot faster with 4.11's right? [​IMG]
    90K5
  6. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    tank you veti much
    high
  7. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    You won't even notice the diffrence betweem 4.09,4.10,4.11. They are so close. 4.11's are more comin and can be found easier...........Dan
  8. HispanicPanic
    HispanicPanic 1/2 ton status
    Mar 21, 2001
    351
    El Paso, Texas
    ok just an example lets say 3.73 gears, they could also be 3.72 is there a diff. no its the same thing cuz what happens is you have 41 teeth on the ring gear and you have 11 on the pinion so when you do the math its 41/11=3.72727272727272 which is how you get 3.72 gears however if you round to the nearest thousands its 3.73 so what im trying to say 3.73 gears if gotten tech. about it are 3.72 and 4.11 are something like 4.106 which are? thats right 4.11s
    its all the same 4.10,4.11 just depends on how you look at it hope i helped
    BEER-- one is none, two is half, and three is one.
  9. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I am running front D44 w/4.09 and rear D60 w/ 4.11.
    <A target="_blank" HREF=http://www.geocities.com/baja/5099>http://www.geocities.com/baja/5099</A>
  10. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    guys I know.....hence the [​IMG]......thanks anyway though.
    90K5
  11. Emmettology 101
    May 9, 2000
    8,126
    FL
    Ya, alot of D44's came from the factory with 4.09's and the 12 bolts that were in the rear were 4.10's or 4.11's....
    You wont notice any ifference between the two/three...
    <font color=green>MIKE</font color=green> - "Hukd on fawnics,werkd fer me!"
    <A target="_blank" HREF=http://www.geocities.com/emmettology101>http://www.geocities.com/emmettology101</A>
