4.10 carrier **update with pics**
Discussion in 'The Garage' started by Grieby54, Jul 1, 2005.
  1. Grieby54
    Grieby54 1/2 ton status
    Jun 18, 2005
    782
    Houston, TX
    I have a carrier for a D60 rear end that had 3.08 gears and I just recently bought a ring and pinion for 4.10 gears. My dad was about to put the ring on the carrier but says they're different diameters. Is this right? Is there something I can do to make it work. If I can't... does anyone have a carrier for 4.10 gears in a D60 rear end...? Help please...
    **Update - The lenth diameter of the outside of the ring is 9.75 inches. The diameter from center of bolt hole to center of opposite bolt hole is 7.5 inches.
    And for the last time... it is a dana 60... here's a freaking picture...** (this is the 4.10 ring)
  2. Grieby54
    Jun 18, 2005
    782
    Houston, TX
    TTT?
  3. chevy_muscle
    chevy_muscle 1/2 ton status
    Mar 16, 2004
    103
    Murphy, tx
    You might try the www.67-72chevytrucks.com board. There are a lot of parts sold on that board and maybe someone has the right carrier for you.
    .... or you could get a locker or something maybe.
  4. blazerpro79
    blazerpro79 1/2 ton status
    Jan 4, 2005
    528
    Simi Valley, CA
    I Think You Have The Wrong Gearset. Iirc, You Need To Buy Thick Gears When Going From Anything Lower Than 4.10 To 4.10 Or Higher. You May Have Bought Standard Sized Gears... Hope This Helps.
  5. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I'm not aware of the diameter changing between different ratios for the same axle, only the thickness of the ring gear.
    The Dana 60 + 3.08 gears just doesn't sound right to me either.......did they even make Dana 60's with that high of a gear? I thought that was what the Dana 61 was made for???
  6. Grieby54
    Jun 18, 2005
    782
    Houston, TX
    Says 60 on my Axel housing, counted up ring and pinion... I have 3.08 gears. But when I unbolt the ring from the carrier, and try to bolt up the 4.10 gears, the 4.10 has a diff diameter... So where can I buy a new carrier... how can I tell if my gears are thick or standard?
  7. blazerpro79
    Jan 4, 2005
    528
    Simi Valley, CA
    oh i misread that... thick and thin gears are not different diameters, they are different thickness...
  8. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    What truck did the axles come from???
    8 lug right????
    Pics and measurements would help...
    3.08's....just doesn't seem right...in a 60.
  9. Grieby54
    Jun 18, 2005
    782
    Houston, TX
    1974 GMC Jimmy, They are Dana 60's, and they are 3.08, they are 6 lug axels. Should I just buy a carrier to match the 4.10's?
  10. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    6 lugs???? Custom rear ??? Not stock rear.. 44/12b's stock.
    Pics???
    Measure the ring gear.
  11. sweetk30
    Nov 1, 2004
    25,554
    547
    horseheads , ny 14845
    dont forget the dana 61 model :eek:
  12. Grieby54
    Jun 18, 2005
    782
    Houston, TX
  13. sweetk30
    Nov 1, 2004
    25,554
    547
    give use a pic of the cover please. i think its not a dana 60. the 60 would be in one of the 4 corner webs not up that far. and would be a lot smaller in size with no gm next to it
  14. Grieby54
    Jun 18, 2005
    782
    Houston, TX
    There she is...
  15. sweetk30
    Nov 1, 2004
    25,554
    547
    :crazy: :( 14 sf rear sorry not dana 60:frown1: that is not a dana cover style. that is for sure a 14semi float 14 bolt 9.5 ring gear.
    left pic dana 60 and right is 14sf 9.5
  16. project84k5
    project84k5 Registered Member
    Sep 14, 2004
    40
    Fort Worth, Texas
    that looks alot more like a 12 bolt than a 14semi
  17. sweetk30
    Nov 1, 2004
    25,554
    547
    12 bolt will be 8.875 outside ring gear not 9.5
  18. Grieby54
    Jun 18, 2005
    782
    Houston, TX
    No... the 4.10 gears are the ones with those diameter (the ones I bought for a D60)... I still have the cover on the whatever the hell I have now... so I don't know the dim.
  19. sweetk30
    Nov 1, 2004
    25,554
    547
    2 totaly diffrent axles. the pics you posted are of 14sf rear. sorry for any problems. but dana 60 stuff wont go in there or vise versa. hope i helped the best posible with what i had to look at.:crazy:
  20. google
    google 1/2 ton status
    May 19, 2005
    805
    Arizona
    He keeps saying 14sf, but he means 12 bolt. JFYI
