4.10 D60 carrier and 5.13 gears?
Discussion in 'The Garage' started by TruckNutzDude, Oct 30, 2003.
  1. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    I know this topic has been covered before. Do thick gear sets exist for the Dana 60 front axle to go from a 4.10 gear to a 5.13? I searched and got both yes and no answers. I can't afford to go to an ARB or a Detroit right now so if no thick gears are avalable it looks like I'll be stuck w/ 4.10's for a while /forums/images/graemlins/mad.gif If you know where I can get the gears at a decent price or even a cheap carrier that'd be awesome. Thanks /forums/images/graemlins/grin.gif (I was hoping to save the carrier and buy a cheaper locker (Lock-Right) for the front since I'm only going to 38.5" tires and don't do rock's.)
  2. jekbrown
    May 19, 2001
    45,032
    366
    Vancouver, WA, USA
    i dunno, but i know the existance of thick gears pisses me off! /forums/images/graemlins/mad.gif my ff14b is factory 4.56... go ahead and try to find inexpensive non-thick 5.13 gears. when u locate some, lemme know!! /forums/images/graemlins/wink.gif /forums/images/graemlins/tongue.gif
    j
  3. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    I'd probably stay with the 4.56's if I had them since I run a lot of mud. Not having to buy gears would save me some cha-ching so I could buy a locker or two. /forums/images/graemlins/rolleyes.gif
  4. jekbrown
    May 19, 2001
    45,032
    366
    Vancouver, WA, USA
    already got detroits f/r...so its all good. /forums/images/graemlins/grin.gif I'll quit trying to hijack/pad now... /forums/images/graemlins/wink.gif /forums/images/graemlins/tongue.gif
    j
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Quit your whining...4.10 down 14 bolt FF carriers are a dime a dozen in the junkyard!
  6. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I did quite a bit of searching when I installed my Dana 60 and could not find any "thick" gearsets for the 60. The only option I found was to use a ring gear spacer, or obviously get another 4.56-up carrier. There are mixed reviews about using the spacer so I'm not sure what to suggest.
  7. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    I'm a machinest by trade and could possibly make the spacer if anyone knows the thickness of it. Other than that I guess I got my answer. Thanks for the quick responses guys /forums/images/graemlins/thumb.gif
  8. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I was searching around for gears for my D60 and came across this...
    http://peakempire.com/new/store.html
    Check out the D60 gear section, says that the Yukon gears they offer come in "Thick" design for the lower ratio carriers.
    Chris
  9. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    Ok, I searched a little more and found the "thick" 5.13 yukon gear set. It's reverse cut? that means it will fit my front, correct? /forums/images/graemlins/thinking.gif
  10. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    oopsss...I totally missed that...I think only the Furd HP D60 are the ones that use the rev. rotation gearz...I guess the search continues...
    Chris
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Reverse cut won't work in a chevy 60, you're correct.
  12. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    You can buy the ring gear spacers from many sources and they are relatively cheap.
  13. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    I feel your pain. That's why I went with the 5.13s & a spacer for now. Picked mine up used. My plan is to up to a locker in the future. Then I can just remove the spacer & carrier and install the locker.
  14. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Yeah, my 5.13 swap was very expensive. It did unload the drivetrain quite a bit though. I stopped breaking transfer case adapters and blowing up drivelines.
  15. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  16. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    I think his web page is broken. I can't see the charts.
  17. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    click on ring and pinions and then select dana and you will see the charts /forums/images/graemlins/thumb.gif
  18. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    The chart on their website may say that, but when I called to ask about them they were not available........
  19. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    Not anailable might have just met currently. It is my understandung that they only make the gear sets a couple of times per year. You may need to check & see if they will become avaialble in the not so near future.
    Anyway, just a thought.
  20. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    Where did you guys get ring gear spacers? I'd much rather do a spacer now than install a locker... the spacer would save me enough money to get the tires I want, not just ones I can afford /forums/images/graemlins/1zhelp.gif
