4.10 to 4.56 in a 14B
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by laketex, May 9, 2001.
  1. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    I've got 4.10s in there now and need to put in 4.56s. What do I need for the swap? Carrier change? I already have a Detroit locker in as well. Thanks.
    Sherman, Tx
    The road goes on Forever and the Party never ends!
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I've wondered this too. Since the 4.10 and down detroit reused the stockopen carrier, if you regear to 4.56 and up you would then need a brand new Detroit, right?
    I have seen where you can buy thick gears (fit a 4.56 on a 4.10 carrier) and this would seem like a better choice than buying a new detroit and a new carrier.
    Just thinking out loud.
    -- Mike
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Guys, dont do anything to the stock carrier!!! The 4.10 and higher gears use the same carrier, whether its the four pin or three pin spider gears. The 4.56 and lower gears use a different carrier that is thicker than the 4.10 and higher carriers.
    In order to use 4.56 gears on the 4.10 carrier, you need to order the 'extra-thick' gears from whoever you are getting them from. These 'extra-thick' gears are just that-thicker gears to fit the 4.10 carrier so you dont have to search for the 4.56 carrier, which could get a little costly. Very simple.
  4. SlyDog
    SlyDog 1/2 ton status
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    Hey Laketex ! Havent seen ya in a while. Hows your bobbin coming along?
    - SlyDog [​IMG]
  5. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    You can get the special "thick" aftermarket 4.56's to fit on your 4.10 case - but that could be pricey.
    Get regular 4.56's and the proper case from a boneyard. Your Detroit will swap right into it (it just replaces the spider gears)
  6. Cliffy
    Cliffy Registered Member
    Oct 8, 2000
    99
    South Lakewood, CO....... FINALLY!!!
    Is there any other gear choices between 4.10 and 4.56 avail for a 14bolt????
    Coil sprung 71 blazer.
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Not in between the two, no. They have 3.42, 3.73, 4.10, 4.56, 4.88 and 5.13. Thats all I know of. I have heard of some people say there were 3.08's, but I have never seen nor read of any.
  8. laketex
    6,220
    North Texas
    Thanks guys. I haven't even run this axle yet, so I was really hoping i didn't have to get a new detroit. I'll research both options and see what comes of it.
    Slydog- I've not touched the truck in about 2 months sorry to say. Been working about 70 hours a week and planning a wedding, doing a lot of stuff with the lady. Although things should settle out by the end of this month and I'll start to haul on it again. I only lack a few little things before she's on the road!!!
    Sherman, Tx
