4.10 to 4.56
Discussion in 'The Garage' started by the_goat, Nov 12, 2003.
  1. the_goat
    the_goat 1/2 ton status
    Sep 13, 2003
    113
    Phoenix, AZ
    I'm sure that this has been answered before but would it be worth going to 4.56 from 4.10. I have a 700r4, 10 bolt front, 12 bolt rear with 35's. I don't see 1 ton in the near future.
  2. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    I don't know if I would go from 4.10 to 4.56 in a set of 1/2 ton axles although I replaced my stock 10bolts with another set of 10bolts with 4.56 gears I would not spend the money on regearing them right now. Depending on how hard you wheel it. Do you keep breaking now because with 4.56 gears and 10bolts and 35" tires it is not a matter of if you will break it is when.....Jason
  3. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    It wouldn't really make a difference going from 4.10 to 4.56. If you have the money it wouldn't hurt. I ran 35's and 4.56's and never had a problem w/strength until I got 39.5's. The axle shafts should be able to withstand 4.56's and 35's.
  4. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    One-ton swap isalmost the same price as re-gearing... look hard enough, and you're sure to find one-ton stuff already at 4:56. Should find 14FF around $250 in the yard, re-gear front 10bolt for around $500, 8-lug adaptors for front @ $200 or so, then new wheels @ $300 for a set. Total:$1250.00.
    Typical re-gear cost w/ labor:$1100.00
    Just do it, you won't regret it. As soon as my lift and tires arrive, 1-ton is next (unless I buy DP_90k5's bumpers) /forums/images/graemlins/thumb.gif
  5. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    That is actually a 3/4 ton swap /forums/images/graemlins/wink.gif
    If you are going to stick with 35's for a while I would try looking for a rear 14 SF with 4.56 and 6 lug axles then regear the front. This way you are upgrading your strengh a little when you spend the money yet keeping a respectable amount of ground clearance. Plus you keep your current wheels and tires saving money over 3/4 or 1 ton gear.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I don't think any factory 14 bolt SF will have 4.56 gears. AFAIK, 4.56s weren't offered in 3/4 ton trucks (and certainly not in light duty 3/4 tons with 6 lug axles) and 14 bolt SFs were not offered in 1 ton trucks.
  7. kennyw
    Jun 9, 2002
    13,223
    94
    I was thinking more along the lines of someones discarded project that was already regeared... For the cost of regearing a 10 bolt there is a fair chance at finding a 14SF that is already set up.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That's true...never thought of it that way. That'd be great. /forums/images/graemlins/thumb.gif
  9. the_goat
    Sep 13, 2003
    113
    Phoenix, AZ
    Thanks for all of the replys.
    John
