4.10's, 4.11's, or 4.56's??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 82K5_6.5L, Mar 11, 2003.
  1. 82K5_6.5L
    82K5_6.5L 1/2 ton status
    Dec 4, 2002
    439
    Tucson, Az
    4.10\'s, 4.11\'s, or 4.56\'s??
    wanting to go to 35's and undecided on which gears to upgrade..got the 700r4..since its got overdrive and all i've heard 4.56's??? some help?
  2. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Re: 4.10\'s, 4.11\'s, or 4.56\'s??
    I run a modified SBC 4.56's, 700, 33-35 (depending on season) tire and I love the combo. With a diesel, I don't know as they have a lower RPM range. I would talk to somebody who has a similar DIESEL setup and see what they think.
  3. 82K5_6.5L
    Dec 4, 2002
    439
    Tucson, Az
    cool, arlight thanx
  4. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    I have the same set up like Leadfoot and I like it as well. And He has a point you mite need to jump in the Diesel Board and see what they like. I doubt it would be different but who knows.
    Eric
  5. Snowbound
    Snowbound Registered Member
    Mar 12, 2002
    52
    Minot N.D.
    I've had 4.56 gears and 33's for almost 3 years with no problems
  6. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,082
    486
    Grand Rapids area
    4.10 and 4.11 are basically the same thing, so you don't need to distinguish between them. FYI, The 4.10's I have are both 41 ring teeth and 10 pinion teeth. For 4.11, I guess you have 37 and 9.
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    With 35s, go at least 4.56 with a 700. I'd go with 4.88s if you ever plan on using a larger tire.
  8. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I ran 4.10 gears with 35" tires, 6.2 diesel, and 700r4 for a couple of years and it did okay though I would recommend going with the 4.56's. The 4.10's were originally installed when I had 33's, and now that I have 38's it's really doggy and I can't use overdrive much at all.
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Like I said, the 4.88s would be ideal for a larger-than-35" tire.
  10. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    5.13's not sure what that would do to the disel.
  11. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Go with 4.88's. With OD there is only a 100 RPM difference at 70 between 4.56's and 4.88's on 35's.
  12. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    last i knew marv springer was running 3.73 with 35's. but he had a th350 and a mild 350SBC. kind of slow off the line i imagine, but i am sure he got good mileage. the 6.5 L does like a lower RPM. and personaly i would go 4.10 and put that low end TQ to the use.
    BUT, then you say 700R4... so 4.56 would be a nice option as well. it will make life easier for what I think is a POS tranny.
    just a personal opinion. dont mind me.
    grant
  13. 82K5_6.5L
    Dec 4, 2002
    439
    Tucson, Az
    hahaha P.O.S. tranny..y dont u like them?? besides that, u think 4.56's would work good?? cuz i wanna do it right u know??
    thanx /forums/images/graemlins/grin.gif
  14. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    5.13's. I have a SBC350/TH350 combo and even with mild power i burned up my tranny in less than 1500 miles.
    with the OD, 5.13's and 35" tires you'll be turning 2200RPM's and it will be easier on the tranny.
