4:10's and 37's?????
Discussion in 'The Garage' started by gmcjimmy88, Apr 8, 2005.
  1. gmcjimmy88
    gmcjimmy88 1/2 ton status
    Feb 10, 2005
    559
    Fayetteville North Carolina
    I have the factory 4:10's and going to 37 inch tires. I had 33's and the gearing was good. What should I be expecting with these gears and tire sizes. Eventually when I upgrade the axles I plan on going to 5:13's or 5:38's. Does anyone run this gear ratio with this tire size. I am just wondering what it will be like on the trails. I would just put them on and see but I am still out of country until mid May so this is really got me thinking. Any help would be great.
  2. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    I have 38's and 4:10's and would definately like more gear... especially with the 2:1 low ratio in my 205.
    My high-stall converter makes up for it a little bit though....
  3. fatboy
    fatboy 1/2 ton status
    Jul 1, 2003
    290
    Tennesse
    I have 4.10 and 37's and want to regear aswell. It is nice on the freeway but want just a little more lowend to get a good feel of my 383 :cool1: I can and will live with it but if I win the lottery that is what I am going to do next (note to self)(must start playing lottery) :)
  4. gmcjimmy88
    Feb 10, 2005
    559
    What diff is evryone running with 37's?
    Curious who is running 37's with 10 bolts.
  5. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    PO Installed a front 10 bolt.... I'm gonna run it til it breaks then look for a 60. With a stroker and 38's it won't be long now.
  6. mrk5
    Apr 20, 2004
    12,351
    1,051
    Northern Colorado
    I'm running 37s with a D44 & 12bolt for 2 weeks now. :dunno:
  7. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    I'm running 37's and 4.56's and I think it is too low. Not that I am going to switch to 4.10's, but I will not switch when I go to 42's. Also, I have a 465 so no overdrive for me.
  8. gone huntin
    gone huntin 1/2 ton status Premium Member
    Oct 25, 2004
    1,706
    Coldwater, MS
    Keep in mind that if you have overdrive or not makes a big difference in which gear you need.
  9. gmcjimmy88
    Feb 10, 2005
    559
    I run the 700r4
    I hope that 410 wont be to bad. As I said I liked the gearing with 33's but going to 37's might be too much.
  10. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Bingo, I have 4.10's with 37's and it is about the right mix for me (TH350 = no OD). I can do 70 on the freeway and still move in town (it is not going to win any races though). I am going to try and run my 40's on the 4.10's too. Might change to 4.56 but who knows.
  11. gmcjimmy88
    Feb 10, 2005
    559
    My concern is not the road at all. My truck rarely hits the road. My concern is offroad. How does this gear/tire setup work.
  12. Emmettology 101
    May 9, 2000
    8,126
    FL
    I think Jerry(JK5) is having ISP problems. But he was running 38's with 4.10's in 1 tons. He had a th350 and he seemed to like it. He is still running the same gears and 44's now... One thing that helps him though is he has a ZZ4... So he has good power! THis is all with a single 205.
  13. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    If you're going offroad then just get the 5.13's unless you're doing high speed desert racing. (and I don't think you are if I do recall you want to do some rock/trail/mud)
