4.10's and 42's is this a bad idea?
Discussion in 'The Garage' started by zakk, Oct 31, 2002.
  1. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    4.10\'s and 42\'s is this a bad idea?
    Well, is it?
    the 39.5's are looking scall and the truck is not really a DD anymore, and when it is going places it is usually at freeway speeds and then in 4LO at the trail. i have no doubler, 1 ton axles, TH350 ~275hp mod'd GMPP 350
  2. GMslave
    GMslave 1/2 ton status
    Oct 3, 2002
    113
    Flint, Michigan
    Re: 4.10\'s and 42\'s is this a bad idea?
    It's gonna be sloooooooooow. But it will work. Swap in a 4 speed, or jus re gear to 4.56 or 4.88.
  3. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    I run 4.10 with 35's and wish they were lower. I would go to 5.13. I am going to 4.88 and run 38's. 42's and 4.10's=no power. The only way I would run that combo would be a BBC and a doubler. my $.02
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I gotta think it would suck. I was running 38s and 4.10s that was pretty borderline, and I have the 465. I'm going to 42s during this buildup and I've installed 5.13s. 4.88s would be fine too, but 4.10s... that's just going to suck. </font color>
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i have 4:10's with a 350ci sm465np205 with 38's and i wish like hell i had 4:88's id say get the 5:13's /forums/images/graemlins/smile.gif if your going to re gear do it right the first time and go with the 5:13's /forums/images/graemlins/smile.gif
  6. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Normally I would agree with rest of the posts, but my friend ran 42's with 4.10 gears for years. It was mostly a mud truck at the time with a mild to moderate 454 and he never really complained. He eventually went with 4.88's when he started doing more trails and now has 38's. On the other hand another friend has 4.88's with 39.5's and wished he had much lower gears.
  7. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    My Crew Cab with 40" tires and 4.10 gears makes the approx. 400 horse 402 feel like a 125 horse 305 at times.
    The truck I just bought has 44" tires and 4.10 gears. When I picked it up from my friend's house, the T-case shifter or front driveline wasnt hooked up. I drove home and gearing and power feld surprisingly good for a 350, almost too good, like my Suburban with 4.10's and 33's. I then realized that the T-case was in 4-low the whole time. First time I drove down the highway in 4-low going the speed limit.
    I have yet to see how gutless the thing is in 2-high.
  8. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    I guess it depends on the type of wheeling you do. Im running 40's, SM465/NP205 and 4:10's and i have no problem on any trails in my area. In 4 low granny gear i can get out and walk next to my truck, which is enough gear for me /forums/images/graemlins/smile.gif
    Brian
    82 Burb
    40" TSL's SM465/NP205, D60/14FF
    welded and rear disc.
  9. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    This is what I'm running right now on a 700r4. It pretty much sucks off the line but once it gets going its cool. Kinda feels like I'm "towing" all the time. This is only temporary, 5.13's are on the way.
    You can check it out <font color="red">IF</font color> I make it to Pismo.
  10. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    hell, to check it out i'll PULL you to pismo!
  11. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I've got a 350TBI/TH400/NP205 with 4.56 turning 42s in a much lighter rig and I feel they are barely border line. You've got some lower gears in the t&amp;t but that won't make up for the diff, especially the weight. I would be hessitant unless you plan to go to a doubler or regear soon, especially if you ever drive on the street...
  12. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    I wouldn't recommend it. My friend has 4.10s with 44s and a mild 355 ci and 465/205 and it's not low enough. But he has 5.13s on the way. I'm running 4.56s with 39.5s and a 465/205 and it does pretty good, even though sometimes I wish I had 5.13s.
    Will
  13. Kamots
    Kamots Registered Member
    Oct 9, 2002
    47
    Oklahoma
    a good idea is to multiply ur tire size by .12 an it will give you a general ballpark on gearing. It comes up with 5.04 meaning you need in the 5's for gears to really move that rig. Good luck either way, its ur rig have fun.. /forums/images/graemlins/tongue.gif
    Kamots
  14. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    I am running 4:56's w/ 38.5's and I intend to upgrade my ratio to 5:13's , Not enough pull for my tastes Off-Road! /forums/images/graemlins/angryfire.gif
    Bill
  15. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Where did you derive with the .12? What exactly is the meaning of doing that? If we knew what that number represented maybe we all would have a better understanding of things.
  16. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    I have a friend with a Bronco on 42's. We geared it 5.13 with no OD and it runs great RPM's at 70. I'd say 5.13, but if you have OD (below 1:1 last gear ratio), go a little lower.
