4.11 gears
Discussion in 'The Garage' started by bleedchevy, Sep 25, 2004.
  1. bleedchevy
    bleedchevy Registered Member
    Nov 4, 2003
    54
    Oakley, MI
    I came across a set of rebuilt 3/4 ton axels with 4.11 gears, will it be to much of a gear for a k5 that sees a lot of on/off road driving? i have a 350, 700r4, 208 set up. i plan on running 33's for now.
  2. Grim-Reaper
    7,385
    Atlanta
    Should be a good combintation with the 700R4. Keep that 700 running cool.
  3. bleedchevy
    Nov 4, 2003
    54
    Oakley, MI
    i did a search, but what is the numeber needed for the conversion ujoint, and will the front need a conversion as well. im finally upgrading from 10 bolts, it so exciting. /forums/images/graemlins/peace.gif
  4. bleedchevy
    Nov 4, 2003
    54
    Oakley, MI
    i found the conversion u joint for the rear, but will i need one for the front d44.
  5. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    No need for a conversion u joint for the front 3/4 ton axle. A 3/4 ton front axle is basically just a 1/2 ton front axle with a couple minor differences (backing plate and outer stubs I think). A 3/4 ton rear axle is exactly the same as a 1 ton rear axle except for spring perches and shock mounts hence the need for a specal rear u joint.
  6. Grim-Reaper
    7,385
    Atlanta
    Probably not need one for the front. I didn't on mine. Front is a 297.
