4.3 in place of a 2.8?
Discussion in 'The Garage' started by y5mgisi, Mar 18, 2005.
  1. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Is it possable? Are the motor mounts the same or are the 4.3 the same as 350s? will clutch from the 2.8 work on the 4.3? is the ('85) 2.8 tranie the same as a 4.3(new clutch flywheel and slave)? We would definetly use a carbed 4.3 sence the 3.8 is carbed. So is this a farily simple swap or is there stuff that im missing?
  2. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    My understanding is that they're different animals. I've heard it's about as much work doing a 4.3 swap as it is doing a 350 swap.
  3. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,175
    132
    Phoenix AZ
    Yes it is possible, but it will NOT be cheap.
    Mounts are not the same as 2.8L. They are the same as 350, but in a different place.
    Clutch and flywheel are different.
    Trans may live with easy driving.
    Bellhousing is different. MIGHT be able to use a V-8 F-body bellhousing to adapt motor to trans. Not sure about pilot diameter being same/different.
    Radiator is different (inlet/outlet on wrong sides)
    I had a customer do this a few years ago and spent a bunch of money to pull it off. With the '88's and newer being relatively cheap, it might be chaper in the end to get one already set up with the 4.3L.
  4. mosesburb
    Apr 20, 2003
    2,175
    132
    Phoenix AZ
    He is right.
  5. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Why not use a 3.4 out of a Firebird or camaro? That's what I did with the 2.8 in my Cherokee. Changed front cover so access drives would work, put in elec. fuel pump cause 3.4 has no mech fuel pump drive, and re-balance flywheel. Better gas mileage, ALOT more power. Has to be out of a Firebird or Camaro cause that's the only RWD 3.4 GM produced.
  6. sweetk30
    Nov 1, 2004
    25,542
    539
    horseheads , ny 14845
    gm performance offers this kit . just a nother idea.
  7. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Deffinetly need more info about this. Is the 3.4 carbed or injected? moter mounts, clutch, exaust, bellhosing? is all that the same? where could i find more info?
